+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 3
    Points: 4,252, Level: 15
    Join Date
    Jul 2012
    Posts
    820
    Points
    4,252
    Level
    15
    Wireless link between organ/piano keyboard & Tesla coil driver circuit
    If my DIY piano/organ keyboard was to output audio then would a simple FM transmitter on the piano keyboard and a simple FM receiver on the tesla driver circuit, whose output feeds into pin 5 of a 555, be a reasonable way to achieve such a wireless link?
    •   Alt28th May 2013, 00:45
      advertising
  2. #2
    Member level 3
    Points: 2,732, Level: 12
    dian's Avatar
    Join Date
    Apr 2006
    Indonesia
    Posts
    61
    Points
    2,732
    Level
    12
    Re: Wireless link between organ/piano keyboard & Tesla coil driver circuit
    did you mean this link to modulate the tesla driver?
    •   Alt31st May 2013, 17:15
      advertising
  3. #3
    Join Date
    Jul 2012
    Posts
    820
    Points
    4,252
    Level
    15
    Quote Originally Posted by dian View Post
    I was intending to take the audio output of the organ thingy and plug it into pin 5 (CTRL) of the 555 that controls the tesla driver circuit.
    In the same way that you can plug the audio out of an ipod into it.
    But I am trying to come up with a way of doing this that doesn't require a wire connection.....for convenience.
    •   Alt31st May 2013, 20:13
      advertising
  4. #4
    Member level 3
    dian's Avatar
    Join Date
    Apr 2006
    Indonesia
    Posts
    61
    Points
    2,732
    Level
    12
    I think you will use the 555 as Pulse Width Modulator and put modulation into pin 5 of the 555,
    and yes you could do it with small fm tx/rx or maybe infra red or any analog transmitter from any audio source..just have to couple pin 5 and some level adjustment
  5. #5
    Advanced Member level 5
    Points: 16,136, Level: 30
    Join Date
    May 2010
    Santa Barbara
    Posts
    2,832
    Points
    16,136
    Level
    30
    If the Tesla coil should spark by audio signal, why not use a simple VOX? This is a Voice-Operated Switch, operates wirelessly, and in the audio amplifier after the microphone you can add a filter for a selected tone, so the Tesla coil will not spark at ANY sound but only one you send from your speaker.
    You can also use a laser pointer as transmitter, and a photodiode switch for the same purpose. Best if you add a small mirror from a flashlight to the photodiode, so it will only respond to your command.
