+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 1
    Points: 1,305, Level: 8
    Join Date
    Apr 2013
    Thrissur, India
    Posts
    100
    Points
    1,305
    Level
    8
    Whats the need of studying control system in electronics?
    •   Alt17th May 2013, 15:20
      advertising
  2. #2
    Member level 5
    Points: 1,299, Level: 8
    Usama Siddiqui's Avatar
    Join Date
    Jan 2012
    Pakistan
    Posts
    87
    Points
    1,299
    Level
    8
    Re: Whats the need of studying control system in electronics?
    basically any electronic circuit without a control system is ,in many places meaningless,whenever u want your output to be sensed with your input in order to stabilize the gain (in case of opamp) or for noise reduction to minimize error,u need a control mechanism to do dat for u,rather then u urself take the screw driver in ur hand and change the potentiometer :D
    •   Alt17th May 2013, 15:51
      advertising
  3. #3
    Advanced Member level 5
    Points: 39,702, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    Quote Originally Posted by akhilpaulv View Post
    Feedback is one of the basic principles applied in electronics.
    Connected with the principle of feedback are the terms "feedback loop", "loop gain", "closed-loop gain", "stability", "stability margin".
    The theory behind all these parameters is provided by studying control systems.
    1 members found this post helpful.
    •   Alt17th May 2013, 16:48
      advertising
  4. #4
    Full Member level 5
    Points: 2,193, Level: 10
    Join Date
    Jun 2012
    San Francisco Bay Area
    Posts
    266
    Points
    2,193
    Level
    10
    Nearly every analog circuit has a feedback loop in it. In designing an analog IC, my chip has upwards of twenty feedback loops. Controls theory is the study of feedback loops, and without understanding the theory you will have much difficulty building feedback loops that work (because making them work is not as trivial as it sounds).
    Additionally, electronics are called on to control non-electronic things using feedback loops, so the task of "controlling" a device (such as a robot, a soldering iron, a washing machine, anti-lock brakes, etc...) often falls on the electrical engineer.
