How to calculate energy in kWh for DC energy measurment in MikroC
swethamenon
Member level 4
In MY PROGRAM FOR DC ENRERY MEASUMENT,have some doubt
voltage in V& current inA
so power in Watts.
each second sensing v& i.
1watt=joules/sec
so to convert into kW/hr(will be a small value).say if joules/sec reaches --(how much value) convert to kWhr.
How to code for this??
HTML:
adcval=Adc_Read(0)*.0048;
adcval1=Adc_Read(1)*.0048;
Is=adcval/330;
I=Is/2.5;
V1=I*5000;
floattostr(V1,val);
val[5]='\0';
lcd_out(1,3,val);
Is1=adcval1/330;
I1=Is1*1000;
floattostr(I1,val);
val[5]='\0';
lcd_out(1,11,val);
power = V1 * I1;
//floattostr(power,p_val);
//p_val[5]='\0';
//lcd_out(2,3,p_val);
energy =(energy + power);
floattostr(energy,val);
//val[5]='\0';
lcd_out(2,3,val);
delay_ms(1000);
P = V * I = I^2 * R
P (in Watts) = V (in volts) * I (in amperes)
E (in joules) = P (in watts) * T (in sec)
Eg: 40 watt lamp is ON for 1 hour
E = 40 watt * 3600 sec
= 14,400 joules
Power in Kilowatts
6Kw + 4Kw + 3 * 100 watt
= 6 Kw + 4 Kw + (100 * 3) W
= (6 + 4) Kw + 300 W
= (6 + 4) Kw + (0.300 * 1000) W
= 10 Kw + 0.3 Kw
= 10.3 Kw
Energy in Kilowatt hours = Power in kilo watts * time in hours
= 10.3 Kw * 10 hours
= 103 kilowatt hours (kWh)
You have to calculate E every 1 sec using
E (in joules) = E + (P * T)
1 joule = 2.77777778 * 10^(-7) kilowatt hours
eg: if E (in joules) is 10000000 then
E (in kWh) = E (in joules) * 2.77777778 * 10^(-7)
= 10000000 * 2.77777778 * 10^(-7)
= 10^(7) * 2.77777778 * 10^(-7)
= 2.7777778 kWh
