+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Newbie level 3
    Points: 31, Level: 1
    Join Date
    Apr 2013
    Posts
    Points
    31
    Level
    pic based modified sine wave inverter
    hi am trying to make a pic based inverter circuit.
    the circuit uses 2 p-channel mosfets(f9540n) with a centre tapped 12-012/230v transformer.
    i programmed the pic to turn on the mosfets inorder to create modified sine wave.
    i assembled circuit with o/p of transfrmr open circuited.i switched on the 12v dc supply but within 5s my breadboard got heated up and started to melt.
    how did this happen???
    pls help
  2. #2
    Super Moderator
    Points: 70,442, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,523
    Points
    70,442
    Level
    64
    Re: pic based modified sine wave inverter
    A schematic is needed to answer that question but I can make a guess at the reason - if you are directly driving the gates of the MOSFETS from the PIC they never turn off, you would be applying the wrong polarity signals to the gates. I assume you have the tap in the transformer grounded and the MOSFET source pins connected to a +12V supply so the best you could manage with a conventianally wired PIC would be VGS between -7V and -12V (12V minus PIC output voltages) when the worst case specification is they turn on with -4V.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
    1 members found this post helpful.
    •   Alt28th April 2013, 14:18
      advertising
  3. #3
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Quote Originally Posted by laxman289 View Post
    pls help
    If I correctly understand you pass high current over protoboard (breadboard) ?
    Breadboard are not for higher currents, its for signals and smaller currents, and for higher currents you should use appropriate wires outside of breadboard.
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.” Nikola Tesla
      advertising
  4. #4
    Newbie level 3
    Join Date
    Apr 2013
    Posts
    Points
    31
    Level
    here is a rough schematicClick image for larger version.
    but how come the current is so high..i havnt loaded the transformer
    Quote Originally Posted by betwixt View Post
    Brian.
    but i checked the operation of mosfet by using led.i turns off with 5v and turns on with 0v(p-channel)
  5. #5
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,523
    Points
    70,442
    Level
    64
    Where is the PIC ground (VSS pin) connected? Remember that to switch the MOSFET on and off you have to apply or remove the voltage between the gate and source. That's difficult to do when the source is connected to the transformer like that. Please post the full schematic so we can check.
    As tpetar points out - breadboard construction isn't really suitable when you are switching many Amps.
    Brian.
    •   Alt28th April 2013, 14:58
      advertising
  6. #6
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    You switch MOSfet sides.
    Example with P-MOSfets
    Example with N-MOSfets :
    MOSFets pins :
    This design gives you square wave shape, and its not good for inductive loads. Search EDABoard threads for modified or pure sinewave inverters.
  7. #7
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,945
    Points
    241,624
    Level
    100
    Wouldn't "modified sine wave" require a different pulse generation scheme with < 50% duty cycle?
  8. #8
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,523
    Points
    70,442
    Level
    64
    It certainly SHOULD be less than 50% although that design doesn't do it. The MOSFETs Laxman289 is using are P-channel though, so the transformer center tap would have to be ground and the source pins conneced to +12V. That should work equally well (OK - reasonably well!) as long as the drive signals are +12V for 'off' and < 8V for 'on' and I doubt the PIC circuit is producing that.
    Brian.
  9. #9
    Newbie level 3
    Join Date
    Apr 2013
    Posts
    Points
    31
    Level
    Brian.
    bt i have checked the mosfets using a led..its switching correctly.the led is flickering.also i seperately used a pic high as well as low output pin to check mosfets switching..i dont think the ampere drawn during no load condition of transformer is high enough to melt bread board and connecting wires.
  10. #10
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,523
    Points
    70,442
    Level
    64
    Please try this then:
    1. remove the PIC completely then connect both the gate connections to the PIC Vss (ground) pin. This SHOULD turn both the MOSFETS off and no current should be drawn at all. Please tell me what actually happens.
    2. With the PIC still removed, connect both the gate connections to the PIC VDD (supply) pin. Again let me know what happens.
    What I'm getting you to do is simulate a condition where the MOSFETs are both conducting and both not-conducting to see if the drive levels can possibly be adequate to switch them on and off. I think I know what will happen but I need you to confirm it.
    Brian.
  11. #11
    Newbie level 3
    Join Date
    Apr 2013
    Posts
    Points
    31
    Level
    U r right the mosfet is aways on.how can i turn off p mosfet while using 12v supply.
    •   Alt28th April 2013, 18:30
      advertising
  12. #12
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Posts
    11,523
    Points
    70,442
    Level
    64
    The only way to turn the MOSFET off is to raise the gate voltage to meet the source voltage, in other words 12V. You confirmed what I suspected, any voltage lower than about 8V would turn the MOSFET on and the PIC is only capable of going up to 5V so it is impossible to it to turn the MOSFET off.
    You have two solutions, one is to replace the MOSFETS with N-Chanel types so the PIC and source pins can both be grounded or, you can add transistor driver stages between the PIC and MOSFET. The transistor driver is probably the easiest solution, just wire NPN signal transistors with emitter grounded, base to the PIC via 1K resistor and collector to 12V through a 470 Ohm resistor. The gate of the MOSFET goes to the transistor collector. Now the PIC can drive the NPN transistor hard on and off and it's collector will go from 12V down to near zero so the MOSFET gets the drive voltage it needs.
    You should note that adding the transistors will invert the PIC signals (PIC pin = 0 means the MOSFET conducts) but as the drive is symetrical anyway it shouldn't make any difference in this design.
    Brian.
