+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Newbie level 3
    Points: 32, Level: 1
    Join Date
    Apr 2013
    Posts
    Points
    32
    Level
    What are the most used electronic components?
    I have recently been getting more and more into hobby electronics. I believe that I would one day like to make a career out of this. There is an electronics surplus store that I get components from but unfortunately it is a 2 hour drive away. At this place the components are very cheap, like pennies for 10, and there are just so many shelves full of trays with what looks like everything I could ever want.
    My questions is, what components are the most used? What should I stock up on?
    What ranges of Capacitors, Resistors, Diodes, and Inductors would I be using the most starting out in electronics?
    Are there any other components I should get while am at it? ICs, Transistors, Relays, Motors, etc? I want to get into Radio and Robotics once I get a grasp on the basics.
    Thanks for any and all help
  2. #2
    Advanced Member level 5
    Points: 33,525, Level: 44
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    tpetar's Avatar
    Join Date
    Sep 2010
    Pancevo-Belgrade, Serbia
    Posts
    6,427
    Points
    33,525
    Level
    44
    Re: What are the most used electronic components?
    Understanding Electronics Components
    http://www.mikroe.com/old/books/keu/00.htm
    All depends what you plan to do. Its good to have good collection of resistors and capacitors, they are often used.
    Look to collect parts based on project needs.
    “Let the future tell the truth, and evaluate each one according to his work and accomplishments. The present is theirs; the future, for which I have really worked, is mine.” Nikola Tesla
    1 members found this post helpful.
  3. #3
    Full Member level 4
    Points: 1,904, Level: 10
    pplus's Avatar
    Join Date
    Feb 2013
    Posts
    206
    Points
    1,904
    Level
    10
    •   Alt26th April 2013, 11:43
      advertising
  4. #4
    Full Member level 3
    Points: 1,291, Level: 8
    Join Date
    Sep 2012
    Posts
    159
    Points
    1,291
    Level
    8
    To me, its resistors, diodes and capacitors.
    •   Alt26th April 2013, 13:52
      advertising
  5. #5
    Newbie level 6
    Points: 231, Level: 2
    Join Date
    Apr 2013
    Posts
    14
    Points
    231
    Level
    Ya you should not collect random components. You should collect them as per your project requirement. But following are some component which will be required in almost all project so you can buy them and remaining resistors and capacitors and ics will be as per your project
    bread board single stand wire 0 to 12 power adjustable supply variable resistor you can buy 10k resistor some leds general purpose transistor that is bc548 op amp ic741 etc
    •   Alt26th April 2013, 21:21
      advertising
  6. #6
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hi trekkiejonny
    it depends on your projects . for example if you are a hobbyist you need to think about what kind of circuits you are interested in then try to collect the required components .
    If you are trying to do something else , you can easily figure out what you need .
    But some of the components are widely used in most of the usual circuits ! like diodes ( like 1n4007 or 1n4148 or ... etc ) or zener diodes or some kind of resistors like 1 k ohm or 10 k or ....
    I think if you start to make circuits you'll get what kind of components you'll need . for instance when you are only using designed circuits then after some days you'll see for example a 2n2222 is widely used so you'll buy many of them !
    Best Wishes
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
  7. #7
    Newbie level 3
    Join Date
    Apr 2013
    Posts
    Points
    32
    Level
    Some great replies thus far, my thanks. I have the makings of a good list to bring with me.
    I should also add that the store is closing and its having a 20-80% off liquidation sale. Found this out after writing my initial post. Seems like the gods wish me to be an engineer , either that or random chance is on my side for a change. Will be going up Tomorrow and again a few days after.
  8. #8
    Super Moderator
    Points: 46,735, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,654
    Points
    46,735
    Level
    52
    One of the best things anyone ever gave me was Radio Shack's best electronics lab kit. 300 projects in one.
    I had done several projects but it was without a breadboard. The R.S. kit has a breadboard which is a major convenience.
    Also handy is a set or two of 10 jumper wires with small alligator clips.
    Cables to connect audio to/from computers, players, amplifiers, etc., with alligator clips.
    Spare replacement plugs for audio, power, etc.
    Resistors used are mostly in the 100 to 1M range (1/2 W).
    In the 1 to 100 range you may find a use for power resistors (1 to 50 W).
    Potentiometers, one each: 1k, 2k, 5k, 10k, 20k, 50k, 100k, 200k, 500k, 1M. (Half my projects use one or more pots.)
    Capacitors .001 uF through 10 uF. Small values can be ceramic.
    Then starting with electrolytics. These get more expensive as the uF value goes up. 10, 22, 33, 47, 100, 220, 330, 470, 1000, 2200, 3300, 4700 uF. 25V rating is adequate for low voltage projects. (Buy inexpensively online from TheCapKing.com)
    Transistors, NPN and PNP. Several each small signal (TO-93).
    A couple TO-220 size.
    If you want to control more than an ampere, consider a few 2N3055 (TO-3).
    A couple dozen 1N4001 diodes (1A, 50V). Also get higher ampere/voltage ratings if you think you'll need them.
    Assortment of zener diodes. 3 to 15 V.
    A grab bag of led's, different colors.
    IC's. A few 555 timers (and 556 dual).
    3914 dot/bar display driver.
    4017 decade counter.
    For logic gates you can derive almost anything from NAND gates.
    A few 4069 hex inverter IC's.
    4066 quad bilateral switch (for analog signals)
    If you use 7-segment displays you'll want 4511, 4543, 7447, 7448. Consider an all-in-one multi-digit counter IC.
    A few adjustable voltage regulator IC's.
    Op amps. Some 741's and 1458 (dual) (Or better types if not too expensive).
    324 (quad) can run from single supply.
    386 low power audio op amp.
    339 comparator.
    Fuses. It's hard to choose what is most needed. Get a few of the type needed in your equipment.
  9. #9
    Full Member level 3
    Join Date
    Sep 2012
    Posts
    159
    Points
    1,291
    Level
    8
    Wow. What a long lists .
  10. #10
    Achievements:
    tpetar's Avatar
    Join Date
    Sep 2010
    Posts
    6,427
    Points
    33,525
    Level
    44
    Quote Originally Posted by Sunny55 View Post
    My friend, you will bankrupt before start of first project.
  11. #11
    Points: 34,226, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,622
    Points
    34,226
    Level
    45
    Blog Entries
    7
    If you can find a contract manufacturer with a garbage bin, you might find scrap boards to salvage parts or ask them for scrap for student contributions to avoid guards getting after you. ;). They will often us the most popular parts.
    I found that scrap metal shops often buy surplus scrap with boards that could not be repaired economically. Then you pay by the weight very economically. I got over 1k$ worth of high power LEDs on aluminum substrates for $20 once from a scrap metal yard just because there was a test flaw on each board. Most of them worked fine.
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  12. #12
    Newbie level 5
    Points: 691, Level: 5
    Join Date
    Dec 2011
    Posts
    8
    Points
    691
    Level
    Resistors (100 ohms, 330 ohms, 1k, 10k, 100k) these are the most commonly used, so get bulk of them...
    Transistors (BC547) most commonly used one
    Diodes (1N4001, 1N4148)
    Capacitors of different values
    Breadboard for testing purpose
    Jumper wire for connections...
  13. #13
    Newbie level 3
    Join Date
    Apr 2013
    Posts
    Points
    32
    Level
    Thank you very much for all the great replies, got just about everything listed except for the mosfets, those where all gone when I got there. This is definitely the forum I will be sticking to for future questions, great help.
    •   Alt7th May 2013, 06:30
      advertising
  14. #14
    Banned
    Points: 281, Level: 3
    Join Date
    May 2013
    Posts
    Points
    281
    Level
    As tpetar said earlier, it is good to collect various capacitors, Resistors, Diodes, Transistors, etc. We often use them depending on the conditions.
