+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Junior Member level 3
    Points: 873, Level: 6
    Join Date
    Oct 2012
    Greece
    Posts
    29
    Points
    873
    Level
    Airbox and PML settings
    Hello, I am trying to create a bandgap diagram in eigenmode for the structure below:
    Click image for larger version.
    but I don't know if I set the correct size of the airbox above the cell and the PML.
    The size of the first airbox is 6h and for the PML I use the recommended value of thickness but
    the minimum frequency of my setup solution and 6h as the minimum radiation distance.
    Can anyone verify that these values are correct?
    Thank you.
    •   Alt23rd April 2013, 16:07
      advertising
  2. #2
    Full Member level 2
    Points: 1,276, Level: 8
    Join Date
    Nov 2011
    Egypt
    Posts
    121
    Points
    1,276
    Level
    8
    Re: Airbox and PML settings
    The air box size should be at a distance of /4 from your structure.
    Regards,
    K.A.
  3. #3
    Join Date
    Oct 2012
    Greece
    Posts
    29
    Points
    873
    Level
    I use 500MHz as minimum frequency to my set analysis. Do I have to set the air box size 0.15m?
    What about the PML thickness and the minimum radiation distance?
    Thank you.
  4. #4
    Banned
    Points: 1,272, Level: 8
    Join Date
    Aug 2012
    North Carolina
    Posts
    113
    Points
    1,272
    Level
    8
    your wavelength at 500MHz is 0.6m while your geometry size is only 8mm, that is saying this is a very E-small problem (geo size is much smaller than wavelength). if you use 0.25 lamda as the thickness of the airbox, imaging how big will be your problem domain. I think if the PML is well designed, it can be put really close to the the object. but a robust PML is certainly not there yet. Try ABC and see if the result makes sense, since your problem is almost quasistatic.
  5. #5
    Join Date
    Oct 2012
    Greece
    Posts
    29
    Points
    873
    Level
    My design has eigenmode as solution type and so I can't use ABC. What do you mean "PML is well designed"? Do you suggest to use the default formulas of PML Wizard?
    •   Alt27th April 2013, 19:13
      advertising
  6. #6
    Banned
    Join Date
    Aug 2012
    North Carolina
    Posts
    113
    Points
    1,272
    Level
    8
    Common PML usage experience is to put it 1/4 wavelength away from the object. The reason for this is that regular PML is proven that it can not absorb evanescent waves at all. That is why 1/4 wavelength is suggested and the fact behind it is to decay the evanescent waves sufficiently. Well designed PML means complex-frequency-shifted PML. it can absorb evanescent waves and thus can be put really close to the object, and the 1/4 wavelength suggestion does not need to be followed. I am not an user of CST or HFSS, thus I can not say what type of PML they are using. But papers has clearly discussed about this for quite a while.
    (https://www.google.com/url?sa=t&rct=...45645796,d.dmQ)
  7. #7
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    I can confirm that in HFSS for eigenmode simulation of planar structures, having the PML 1/4 of a wavelength from the structure gives the same results (or as much as is discernible) as having it to within 1/30 of a wavelength. As far as I can tell from the information provided, your setup looks correct.
    1 members found this post helpful.
  8. #8
    Join Date
    Oct 2012
    Greece
    Posts
    29
    Points
    873
    Level
    First of all, thank you for your answers.
    For the PML, do I have to use the default values provided by the wizard or I must change them according to the design (minimum frequency, thicknesss and radiation distance)?
  9. #9
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    I typically use default values - although if the radiating distance is too small I generally try to increase the size of my vacuum. Usually it's pretty close to what I need anyways.
  10. #10
    Join Date
    Oct 2012
    Greece
    Posts
    29
    Points
    873
    Level
    Increase the size to match the radiating distance?
    Another question is how to set the ground correctly. In some examples, ground is a perfect conductor box of some thickness. In the above project, I use a plane material assigned to Perfect E (plus Infinite Ground Plane).
    What do you suggest?
    •   Alt29th April 2013, 21:42
      advertising
  11. #11
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Yes, plus a bit of a safety region, say 5%.
    A volumetric PEC behaves the same on the surfaces as a plane PEC. Personally, I'd go with a volumetric box so that later you can change it to a copper material for increased accuracy.
