+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 6
    Points: 855, Level: 6
    Join Date
    Jul 2012
    Korea
    Posts
    14
    Points
    855
    Level
    Metamaterial unit cell simulation with Floquet Port and periodic boundary condition
    Any one able to correct this setup of metamaterial unit cell with periodic boundary condition and floquet port. What should be the size of the airbox. And what should be the orientation of unit cell. And What should be the criteria to choose the scan angles for phi and theta. And How we can run metamaterial unit cell with periodic boundary simulations in a fast sweep in hfss 13.
    •   Alt21st April 2013, 17:39
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,096, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    953
    Points
    6,096
    Level
    18
    Re: Metamaterial unit cell simulation with Floquet Port and periodic boundary conditi
    Hi sc4rppph,
    As a disclaimer, I don't use Floquet ports, but the setup looks correct to me as far as I know (HFSS 13). For the master/slave boundaries, you probably just want to use the specified phase angle rather than theta/phi for square structures. To get the dispersion diagram, set the phase angle of Slave X to a variable AngleX and phase angle of Slave Y to variable AngleY. Using Brillouin zone notation, Gamma to X is SlaveY = 0 and SlaveX varies from 0 to 180 degrees.
    •   Alt29th April 2013, 19:29
      advertising
  3. #3
    Newbie level 5
    Points: 187, Level: 2
    Join Date
    Apr 2013
    Posts
    8
    Points
    187
    Level
    Hi.
    I really need some help with HFSS in designing Metamaterial Spiral Antenna. I've done some designs in HFSS following a journal paper but I'm getting slightly different results. Using the capacitance & inductance values given in the journal paper, i'm getting a bandgap in the dispersion diagram even though they got no bandgap. I'm pretty sure i'm doing something wrong in the settings or something. If you are free, can u pls take a look at my files. My email is ihos2@student.monash.edu
    The journal paper is doing rectangular spiral antenna & I'm trying circular spiral. I tried the unit cell's dispersion diagram for both rectangular & circular. Both of them were supposed to give same results but both are giving a band gap. So I changed the capacitance & inductance values until i got a smooth graph with no bandgap. but the bandwidth is narrower. I've attached the files for circular ones bcoz i've lost the rectangular ones.MTM spiral.rarDual-band Counter Circulary Polarized Radiation from a Single arm metamaterial based spiral ante.pdfWeek 8 Progress Report.pdf
    Iftekhar
