Explain me this audio transformer specifications
aasif
Audio Transformer Spec.
What are the meanings of the following spec.?
Audio Transformer ( 200K to 1K CT Input)
Re: Audio Transformer Spec.
The primary has an impedance of 200kOhms and the secondary has an impedance of 1kOhms.
CT means Center tapped (the coil has a midle wire).
    aasif
It means that the turn ratio is such that it transform a 200K to 1K
