Importing Allegro PCB into Mentor Expedition PCB
singhjaya
Newbie level 6
Madras
allegro to expedition translator
I need to edit a PCB which was originally done in Allegro, with Mentor Expedition PCB.
Does anyone know how to import or convert the Allegro file?
allegro to expedition conversion
Yes, you can do it. You will need both an Allegro AND a Mentor Expedition license
Mentor WG2004 provides a set of SKILL script files that should be used within Allegro. Theese will prepare the design for Mentor. The design can then be read in into Mentor Expedition.
OR
You can probably use a translator from Router Solutions, Inc. You will need a "from" license, the license of the tool itself amd a "to" license. It is most likely less expenceive to purchase a single conversion which the company also provides.
