+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 5
    Points: 881, Level: 6
    AlienCircuits's Avatar
    Join Date
    Jun 2012
    Posts
    81
    Points
    881
    Level
    Phase margin of an already inverted system
    I am designing a feedback system, and I frequently see that phase margin is computed as the cross over frequency phase + 180 degrees, which tells me how far I am from -180 degrees at the cross over frequency, and so it tells me how close I am to the point that I've completely inverted my control signal.
    In my case, my control signal is already inverted naturally, and so at DC frequency, I already have 0 phase margin technically according to these formulas.
    So my question would be how do I find the phase margin of a system that starts at -180 degrees? Would I start at -180 degrees and see how close I am to -360 degrees as I approach my cross over frequency?
    I've attached my Phase response of the plant and feedback sensor transfer functions combined to see what I'm talking about.
    Click image for larger version.
Name:	Gp + H phase.jpg
    •   Alt18th March 2013, 21:00
      advertising
  2. #2
    Super Moderator
    Points: 241,537, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,932
    Points
    241,537
    Level
    100
    Re: Phase margin of an already inverted system
    A evryone knows, phase is cyclic with 360°. So in your diagram, presuming it's actually showing the overall loop phase, -360° would be the reference for phase margin. For valitidy of the simplified phase margin stability criterion, there must not be multiple crossings of the n*360° line.
    In simple words, phase margin is the distance to the oscillation condition: Loop gain = 1 (gain understood as a complex quantity, describing both magnitude and phase).
    1 members found this post helpful.
    •   Alt18th March 2013, 21:21
      advertising
  3. #3
    Member level 5
    Join Date
    Jun 2012
    Posts
    81
    Points
    881
    Level
    Thanks for the great answer. The loop phase shown is only my plant and my sensor combined . . my next step is to design the compensator, and I wanted to make sure I understood my situation correctly since I'm used to seeing reference to 0 degrees. I only have one unity gain crossing, and so I believe the phase margin criterion should be sufficient for stability.
Name:	loop gain magnitude.jpg
