+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 3
    Points: 1,879, Level: 10
    Join Date
    Oct 2004
    Posts
    59
    Points
    1,879
    Level
    10
    May calibre run LVS check in mixed-signal design?
    In mixed-signal design, there's schematic in analog part, and verilog netlist in digital part, may calibre run LVS check based on this condition? How can I do it? Thanks for your help!
    •   Alt6th December 2004, 13:24
      advertising
  2. #2
    Advanced Member level 3
    Points: 8,029, Level: 21
    Join Date
    Jun 2003
    Posts
    717
    Points
    8,029
    Level
    21
    Calibre has a tool to change verilog to spice. But you need the spice netlist for each standard cell definition.
    [size=2]Best Regards,[/size]
    [size=2]Hughes[/size]
    •   Alt6th December 2004, 13:46
      advertising
  3. #3
    Member level 3
    Join Date
    Oct 2004
    Posts
    59
    Points
    1,879
    Level
    10
    Re: May calibre run LVS check in mixed-signal design?
    I run v2lvs to convert verilog to cdl netlist by using as this:
    v2lvs -lsp stdcell.v -lsp *v -o output.cdl -s0 gnd -s1 vdd -v top_verilog.v
    But I met another question, since I define the bus such as cir[0-31], and which is not recognized, how can I resolve it?
    I know there's another way to run LVS using dracula in mixed-signal design, but I don't know the detailed flow.
