[SOLVED] Doubt in Verilog module instantiation.. Help Me please....
naveeneceng
Newbie level 2
I have a sub module
module RCAF(a,b,s,cout);
input [3:0] a,b;
output [3:0] s;
output cout;
wire c1,c2,c3;
here input a b are 4 input buses...
if i want to instantiate the above module
RCAF A1((a.s2),(b.s3), // here s2 nd s3 are 4 bit buses.
(s.s5),
(cout.c1));
Say if i want to pass bitwise say i want to pass particular value for a[0]. i wrote
RCAF A1((a[0].s2[0]),(a[1].s2[1]),(a[3].s2[3]),(b[0].s3[0]), // here s2 nd s3 are 4 bit buses.
(s.s5),
(cout.c1));
but while running synthesis in Xilinx ISE it shows error as
MUL_FOUR.v" line 57 Too many port connections in instance 'A3' of module 'RCAF'
How to do that.....????? help me please
I have no idea.
How about you post the FULL code so it's easier to read. Also, please use either CODE or SYNTAX tags. See this for some info:
I have no idea.
module MUL_FOUR(A,B,P);
input [3:0]A;
input [3:0]B;
output [7:0]P;
reg [3:0]s1,s2,s3,s4,s5;
reg c1,c2,c3,s6;
parameter zero=0;
MUL_TWO M1((A.A[1:0]),
			(B.B[1:0]),
			P.s1[3:0]);
MUL_TWO M2((A.A[3:2]),
			(B.B[1:0]),
			P.s2[3:0]);
MUL_TWO M3((A.A[1:0]),
			(B.B[3:2]),
			P.s3[3:0]);
MUL_TWO M4((A.A[3:2]),
			(B.B[3:2]),
			P.s4[3:0]);
RCAF A1((a[1:0].s2[1:0]),(a[3:2].s2[3:2]),
			(b[1:0].s3[1:0]),(b[3:2].s3[3:2]),
			(s.s5),
			(cout.c1));
RCAF A2((a[1:0].s1[3:2]),(a[3:2].s4[1:0]),
			(b.s5),
			(s.p[5:2]),
			(cout.c2));
HA HA1(c1,c2,s6,c3);
RCAF A3((a_l[0].s6),(a[0].c3),(a[1].zero),(a[2].zero),a[3].zero,
			(b[0].s4[2]),(b[1].s4[3]),(b[2].zero),(b[3].zero),
			(s[0].P[6]), (s[1].P[7]),GND);
endmodule
// sub module
module RCAF(a_l,a_h,b_l,b_h,s,cout);
input [1:0] a_l,a_h, b_l,b_h;
output [3:0] s;
output cout;
wire c1,c2,c3;
FA FA0(a_l[0], b_l[0], 1'b0, s[0], c1);
FA FA1(a_l[1], b_l[1], c1, s[1], c2);
FA FA2(a_h[0], b_h[0], c2, s[2], c3);
FA FA3(a_h[1], b_h[1], c3, s[3], Cout);
endmodule
Errors:(while synthesis
ERROR:HDLCompilers:92 - "MUL_FOUR.v" line 57 Too many port connections in instance 'A1' of module 'RCAF'
ERROR:HDLCompilers:92 - "MUL_FOUR.v" line 57 Too many port connections in instance 'A2' of module 'RCAF'
ERROR:HDLCompilers:92 - "MUL_FOUR.v" line 57 Too many port connections in instance 'A3' of module 'RCAF'
You seem to be a bit confused when it comes to port mappings.
I suggest reading this one, since it covers quite a few useful things: http://www.sunburst-design.com/papers/CummingsDesignCon2005_SystemVerilog_ImplicitPorts.pdf
And just on the off chance this is going to be your next reply: no I will not fix your code. Just read the suggested pdf and you will be able to fix your own code. :) Good luck!
edit: forgot to mention ... you want to change your code, and use the "2.2 Verilog named port connections" from page 3 in that pdf.
