How to output to a 7segment display without the decoder?
mesalem
Junior Member level 3
74ls47 to serial
Is there a way to output to a 7segment display without the decoder. I am looking for a part that can take 4 bits and display those bits on to a 7 segment display.
Re: help 74LS47
If you have enough I/O pins your processor might be able to do this task without any external components (depends on the current consumption of your display).
best regards
Re: help 74LS47
As C-Man said this can be done.
In most cases the micros pins will be able to sink approximately 20mA of current and you will have to use 7-segment display with common Anode.
The code inside the micro will have a look-up table for conversion from BCD or anything else to 7-segmant ...
help 74LS47
If your signals displayed are from mcu, the method mentioned above is ok, if they are from CPLD or FPGA, the qestion becomes simple. their output can drive 7 segment display directly. it is very simple to program 7 segment display code, you can refer to some design example.
Re: help 74LS47
Your question seems quite confusing. The 74LS47 part does exactly what you need, which is to drive the display using a 4-bit input. If you are short on pins, there are refresh tricks that could be played on multiple displays. You've got to clarify your query.
Re: help 74LS47
you can use serial/parallel regester as 74ls164 that need tow wire in input and connect 7-segment with output
help 74LS47
why not use 74LS47, i think it is very convenient to design 7 segment display.
Re: help 74LS47
another options are cd4543 and cd4511,both easy to use and can drive the segments directly
help 74LS47
I heard of HEX display. It will serve ur purpose
if u use any microcontroller or anyother only use pgming.
