calling matlab in C... if possible then how?
cedance
Advanced Member level 2
Germany
calling matlab dll from c
hi,
i am in need of calling matlab from with in C program for calculating a prt of the output. This has to be fed to the next stage. how can i invoke matlab from within C environment to do this? is it possible similar to running some dos comands within C? if not is it possible to do cluster computing with matlab(running a program on several comp. by splitting them into independent modules)... if so how to do it?.. and i know abt the distributed computing toolbox that has been issued by mathworks just now... which was not avaibale in the m14sp1 release...
/cedance
c invoke matlab
See whether the following articles will help:
Solving Engineering Problems Using MATLAB C API
MATLAB Shared Library
https://www.codeproject.com/dll/MatlabSharedLib.asp
Solving Engineering Problems Using MATLAB C++ Math Library
    cedance
calling matlab function from c
h**p://www.codeproject.com/samples/matlab_c_api.asp
h**p://www.codeproject.com/dll/MatlabSharedLib.asp
h**p://www.codeproject.com/samples/MATLAB_Cpp.asp
i need to call matlab from C and not the other way! thou, thanks for the links. was useful. i need it anyway.
/cedance
Re: calling matlab in C... possible?
I think the links show examples that call matlab function from/in C. Pls correct me if I'm wrong. Thanks.
Using C Math Library
To add support of MATLAB C Math Library follow these instructions:
1- Add following line at the end of stdafx.h
#include <matlab.h>
matlab.h is interface of MATLAB APIs. Add directory of MATLAB interface files (*.h) to Visual Studio (Tools -> Options -> Directories). For example: x:\matlab\extern\include where x is drive letter of matlab path.
2- Add desired libraries to your project (In this example, libmat.lib, libmx.lib, libmatlbmx.lib and libmatlb.lib)
3- Compile your project!
Sample Program
#include "stdafx.h"
int main(int argc, char* argv[])
double dblArray[]={1, 2, 3, 4, 5, 6, 7, 8, 9};
mxArray *A, *B; A=mxCreateDoubleMatrix(3, 3, mxREAL);
//copy array to matrix A
memcpy(mxGetPr(A), dblArray, 9 * sizeof(double));
A=mlfMTimes(A, A); //A=A.^2;
mlfPrintMatrix(A); //Creating Magic Matrix
B=mlfMagic(mlfScalar(3)); //Magic matrix of order 3
mlfPrintMatrix(B);
mxDestroyArray(A);
mxDestroyArray(B);
return 0; }
yeh, i think u are right, can try with C. thanks. will try it and reply.
/cedance
Yes, of course you can.
The most recommended method connecting C and matlab is MBuilder.
You can find help in matlab soft.
Good luck!
yes it is possible,
you can use a generic perl script also for that.
TRY THIS LINK.....
I THINK IT HAS GOT UR ANSWER
h**p://tiger.la.asu.edu/Matlab/call_c_functions.htm
There is a demo program given in the link above:
myprog.c
But it's a demo of calling a C function from MATLAB
If I'm not mistaken, arunmit168 is looking for a solution of calling matlab (function) from C program :)
If I'm not mistaken, arunmit168 is looking for a solution of calling matlab (function) from C program Smile
i think i made the same mistake that u made beforenicleo
anyway sorry for the post
mexx
