+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 30
  1. #1
    Points: 1,368, Level: 8
    Achievements:
    7 years registered
    Join Date
    Mar 2010
    India
    Posts
    7
    Points
    1,368
    Level
    8
    Read SMS From GSM Module : SMS Based Control System By 8051
    Hello, i am designing SMS Based Device Control System Using AT89S52, i have some trouble reagrding SMS reading...
    Through Mobile SMS i need to control assume 4 devices in circuit so i mean i will message in short like this...
    D1 - Device 1 ON
    D2 - Device 2 ON
    D3 - Device 3 ON
    D4 - Device 4 ON
    to gsm module this sms is sent, but now the trouble comes, that how to read this sms and give the signal to 8051 controller to operate according device...
    in simple way i need to read sms that i sent like D1 sms for controlling Device 1, how to read this sms that will help me to control the devices... please help me if someone give me full sms reading code tutorial then surely appreciated...
  2. #2
    Full Member level 5
    Points: 1,942, Level: 10
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    Re: Read SMS From GSM Module : SMS Based Control System By 8051
    go through the following file u will get the idea.............
    10 members found this post helpful.
    •   Alt15th January 2013, 10:17
      advertising
  3. #3
    Achievements:
    7 years registered
    Join Date
    Mar 2010
    India
    Posts
    7
    Points
    1,368
    Level
    8
    bit confused in functions written in the program.. so it would be better to run this program with little change with my program (only LCD programming change) then see what happens... anyway jjeevan007 thanks...
    2 members found this post helpful.
  4. #4
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    if u want u can delete the displaying part........
    main thing is receiving the data from gsm its correct which works fine..........
    if u have any doubts u are welcome
  5. #5
    Newbie level 3
    Points: 23, Level: 1
    Join Date
    Mar 2013
    Posts
    Points
    23
    Level
    thanx for the code. what are u comparing in the code with two mobile nos?
  6. #6
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    controlling of the devices is using only a predefined number only......
    thats why we are comparing the two mobile numbers
  7. #7
    Newbie level 3
    Join Date
    Mar 2013
    Posts
    Points
    23
    Level
    what is the keyword that has to be messaged to gsm modem to switch on a device?
    thanx
  8. #8
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    those are called at commands
    just google it u can find lot of information on GSM at commands........
    go through the following site
    http://www.engineersgarage.com/tutorials/at-commands
    •   Alt2nd March 2013, 06:53
      advertising
  9. #9
    Newbie level 3
    Join Date
    Mar 2013
    Posts
    Points
    23
    Level
    Thanks jjeevan007. actually i am building a security system which will send sms if the system gets interrupted. For activating the system i want to send a sms to the system. i am able to send sms from gsm modem to mobile but i am unable to receive the sms in gsm modem using 89s52. Please help me.
    Thankssss....
    •   Alt2nd March 2013, 10:30
      advertising
  10. #10
    Newbie level 3
    Join Date
    Mar 2013
    Posts
    Points
    23
    Level
    please help me.....
    please help me.....
  11. #11
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    why dont u activate the security system using the push button........
  12. #12
    Junior Member level 1
    Points: 264, Level: 3
    Join Date
    May 2013
    Posts
    17
    Points
    264
    Level
    Quote Originally Posted by jjeevan007 View Post
    Hii
    I want to jnow where's the attached file I m also workinmin tne project and having dificulties with ciding
  13. #13
    Banned
    Points: 23,048, Level: 36
    Join Date
    Dec 2012
    Bangalore, India
    Posts
    4,294
    Points
    23,048
    Level
    36
    gsm.txt is attached in post #2. You have to register and login to access the file.
    1 members found this post helpful.
  14. #14
    Join Date
    May 2013
    Posts
    17
    Points
    264
    Level
    Is that the full program or I need to change something in that??
    Thanks
  15. #15
    Full Member level 5
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    it is the full program, it displays the message on to the lcd
  16. #16
    Join Date
    May 2013
    Posts
    17
    Points
    264
    Level
    Thanks sir...
    I think it will control the devices too that are connected to the uc and as well as display the message on the lcd??
    Am I right??
    Thanks
    •   Alt8th May 2013, 19:45
      advertising
  17. #17
    Newbie level 2
    Points: 26, Level: 1
    Join Date
    Jun 2013
    Posts
    Points
    26
    Level
    i do not get the functions data_res() and data_send what do these functions do
  18. #18
    Full Member level 4
    Points: 2,538, Level: 11
    Achievements:
    7 years registered
    g_shyam1682's Avatar
    Join Date
    Jan 2010
    Udaipur-Rajshan-India
    Posts
    206
    Points
    2,538
    Level
    11
    Hi
    data_send function is used to send AT command to GSM module.
    data_res function is used to read AT command response from GSM module but i think data_res function is not write properly to handle reply from GSM module it just flush out data from GSM module.
    Regards,
  19. #19
    Newbie level 2
    Join Date
    Jun 2013
    Posts
    Points
    26
    Level
    i am designing the same project on pic18f452 i have made changing to the above code can you please tell me if my code is correct
    regards
  20. #20
    Newbie level 2
    Points: 271, Level: 3
    Join Date
    Sep 2012
    Posts
    Points
    271
    Level
    I have doubt about where the received message is stored? Is it in the the SBUF of the 8051 microcontroller?
