+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Advanced Member level 2
    Points: 3,048, Level: 12
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    Op-amp AC characteristics measurement
    Dear Friends
    I finished the simulation of my op-amp design. Now I would like to know the real measurement setup for every test. Starting here in thispost with simulating the AC characteristics (Open loop gain, f-3dB, Phase Margin) .
    As you know that dealing with an open loop amp is really difficult, therefore an approach like the one I attached is used for this purpose. The problem I dont understand how it working and by which equiepemnt we can scan the frequency and how we can read it to be like the one we simulate.
    Please i really need your kind help
    Regards
    •   Alt6th January 2013, 15:05
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Re: Op-amp AC characteristics measurement
    Hi Junus,
    the shown test setup has unity gain for dc only - that is necessary to ensure an operating point within the opamps linear range. Otherwise, the offset voltage would bring the output into saturation because of the large open-loop dc gain.
    The capacitor C should be as large as possible because - together with the large R - it creates a large time constant equivalent to a very low corner frequency wc.
    Thus, for frequencies above wc the inverting input (increasingly) is ac grounded and you can measure/simulate the open-loop gain by connecting a swept frequency signal at Vin.
    The load componenets (RL and CL) are not too important. Thus, some kind of normal operation conditions are established..
    Remark: The rising linear curve starting at 1/RC is the inverse feedback factor 1/Hf with Hf=1/(1+sRC). Thus, the bold line is identical to the gain of the whole circuit (with feedback).
    The crossing of both functions gives you the frequency w1=Av(0)/RC above which the measurement is identical to the desired open-loop gain of the opamp alone. This curve clearly shows why you should select a large time constant RC.
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Signal generator, attenuator, level measurement, e.g with an oscilloscope.
  4. #4
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    Thank you very much LVW
    your explanation is very sufficient , I think you are a teacher in this subject really
    I hope to see your replies with the next measurements I would post
    Thank you in advance Sir
    Regards
    Quote Originally Posted by FvM View Post
    Kindly, If it is possible for you to suggest me the equipment,
    Any way how could I measure the phase Margin ??
    •   Alt6th January 2013, 19:29
      advertising
  5. #5
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Quote Originally Posted by Junus2012 View Post
    Measure or simulate?
    Or estimate? In this case, I guess the phase margin in case of unity gain feedback is only PM=5...10 deg.
    (It is determined based on the corresponding phase response, which can be approximated from the gain slope at the cross-over frequency).
    •   Alt6th January 2013, 21:30
      advertising
  6. #6
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    I mean measuring the phase margin, how to do that practically from the oscilloscope ?
    Quote Originally Posted by LvW View Post
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    You don't primarly measure phase margin, you determine the phase of the open loop transfer function which allows to calculate phase margin for specific feedback factors.
    The phase can be measured with an oscilloscope if you don't have special instruments for this purpose (e.g. a vector network analyzer). The input signal or a respective reference signal from the signal generator have to be connected to the oscilloscope too. Modern DSOs have suitable measurement functions to determine phase differences accurately.
  8. #8
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    As an alternative, you can measure the step response of the closed-loop using the oscilloscope. The overshoot you can observe is a good indication of the phase margin.
    There are graphics overshoot=f(phase margin), which can be used for this purpose.
    This relationship normally holds for second order circuits only, but can be used with good accuracy also for third-order systems (this sufficient for opamp applications).
    •   Alt7th January 2013, 08:06
      advertising
  9. #9
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    Thank you very much guys for your kind explanation, I will think more about it to ask you further
    Have fun
    Best Regards
  10. #10
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    Dear FvM and LvW
    I have found this paper to calculate the phase margin from the step response overshoot , but the equation he used is not clear. Kindly, do you have any clear article regarding the same methods ??
    many thanks
  11. #11
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Junus,
    I think - the equation is quite clear: PM as a function of the damping factor, which is identical to 1/2Q.
    However, this requires the knowledge of Q for the closed feedback loop.
    Therefore, I attach a copy from a textbook (S. Franco: Design with opamps and analog int. circuits).
    There you can find a graph overshoot=f(PM).
  12. #12
    Join Date
    Jan 2012
    Italy
    Posts
    576
    Points
    3,048
    Level
    12
    Thank you very much LvW, so nice
