+ Post New Thread
Results 1 to 17 of 17
  1. #1
    Newbie level 5
    Points: 1,510, Level: 8
    Join Date
    Nov 2004
    Posts
    9
    Points
    1,510
    Level
    8
    analog ground and digital ground
    what is the difference between digital and analog ground ?
  2. #2
    Full Member level 5
    Points: 5,619, Level: 17
    Join Date
    Jan 2000
    space
    Posts
    264
    Points
    5,619
    Level
    17
    analog ground
    The diference is the noise. The digital gnd is much more noiser that analog agnd, so they should not be mix up to avoid coupling from digital noise to analog.
    Bastos
    1 members found this post helpful.
  3. #3
    videohu
    difference between analog and digital ground
    Usually, digital ciricuits are more robust to noise, which have only two value 0,1. The analog circuits work on specific working points depending on requirements. the working point is easy to drift due to noise. So the best way is to avoid the large current circle from digital section runing across analog circuit. point connection between digital gnd and analog gnd is usually preferred.
    •   Alt21st November 2004, 13:32
      advertising
  4. #4
    Advanced Member level 3
    Points: 9,252, Level: 23
    djalli's Avatar
    Join Date
    Nov 2001
    1600 Pennsylvania Avenue, Washington DC 20500
    Posts
    825
    Points
    9,252
    Level
    23
    digital ground analog ground
    Quote Originally Posted by bastos4321
    Bastos
    Use decoupling capacitors (for IC...etc) and in real life you can use analog ground for digital ground at the same time. I know it works pretty good.
  5. #5
    Full Member level 5
    Join Date
    Jan 2000
    space
    Posts
    264
    Points
    5,619
    Level
    17
    analog ground digital ground
    In IC design (inside chip) the decoulpling values avaible are very limitted so it does not work. You have to separate grounds.
    Obviosly in discrete you can use good decoulpling and coexist only with one ground, but that is not the best way to do it.
    Bastos
  6. #6
    Full Member level 6
    Points: 7,637, Level: 20
    Join Date
    Jan 2002
    Posts
    336
    Points
    7,637
    Level
    20
    Digital GND is noisy because the well/sub are locally connected to the sources of P/N mos and the mos are switching from rail to rail. On the contrary, analog GND is relatively quiet because the it deals with small signal mostly.
    •   Alt23rd November 2004, 03:24
      advertising
  7. #7
    djalli's Avatar
    Join Date
    Nov 2001
    Posts
    825
    Points
    9,252
    Level
    23
    Bastos
    Bastos, you can place decoupling capacitors in IC socket (not inside the IC chip). Connect them from first pin to last pin of IC with cap (sometimes these caps can be called bypass capacitors). Although I have not tried with high speed signal.
    I tried one common ground for both analog/digital ground but working signals up to 40khz and it worked good. I digitized and recorded in 10mb memory and played back the recorded digitized signal. Everything a big circuit, just 1 ground.
  8. #8
    Full Member level 5
    Points: 1,993, Level: 10
    Join Date
    Feb 2007
    Posts
    241
    Points
    1,993
    Level
    10
    digital ground and analog ground
    difference is interms of noise,design etc......
    •   Alt4th March 2007, 10:39
      advertising
  9. #9
    Points: 12,011, Level: 26
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    spherulite,
    In an ideal world, there is no difference. In the real word, ground connections have both resistance and inductance. Good practice dictates that the layout be arranged such that ground currents from the digital circuits do not flow through the ground path for the analog circuits. Ultimately, the two grounds must be connected together. This should be done at the power supply.
    Regards,
    Kral
  10. #10
    Full Member level 5
    Points: 2,708, Level: 12
    eelinker's Avatar
    Join Date
    Feb 2006
    PERSIA
    Posts
    269
    Points
    2,708
    Level
    12
    analog and digital grounds
    I highly recommand reading behzad razavi's book (analog cmos ic design) he has described the difference under the title substrate noise page 663.
  11. #11
    Full Member level 4
    Points: 3,747, Level: 14
    Join Date
    Nov 2005
    Posts
    236
    Points
    3,747
    Level
    14
    analog digital ground
    if there are analog and digital grounds, what would the return path be at the moment of communicating 2 signals between the analog and digital block? Both grounds should be connected in one point ?
  12. #12
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    separate analog and digital ground
    STOIKOV,
    Yes, the two grounds must be connected together at one point. In many ICs, such as A/D converters, the two grounds are brought out to separate pins on the IC package. In this case, the terms "analgo ground" and "digital ground" refer to internal functions of the chip. In this case, most manufacturers recommend that the two grounds be connected together at the chip, with as short a connection as possible.
    Regards,
    Kral
  13. #13
    Newbie level 5
    Points: 1,064, Level: 7
    Join Date
    Mar 2007
    Posts
    9
    Points
    1,064
    Level
    7
    difference between analog digital ground
    the main difference between digital & analoge signal is the digital signals are in the form of 0 & 1 that is there is continous chain of zeros & ones that form digital signal
    but the analoge signal is in the form of a wave just like ups & downs with certain amplitude & frequrency
    the example of digtal signal is the signal from the DC source
    while example of the analoge sinal is domestic electricity supply
    •   Alt19th March 2007, 21:27
      advertising
  14. #14
    Full Member level 2
    Points: 3,074, Level: 13
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    147
    Points
    3,074
    Level
    13
    digital analog ground
    I agree with the above posts that digital ground is noisier than analog ground. And as it is suggested, it is a good and safe practice to have separate grounds for analog and digital circuits. These are usually brought out as separate pins which are finally connected together on the board. This actually lowers the effects of coupling as the connection is outside the chip.
  15. #15
    Full Member level 6
    Points: 4,873, Level: 16
    Join Date
    Apr 2005
    Posts
    391
    Points
    4,873
    Level
    16
    Quote Originally Posted by Kral
    STOIKOV,
    Regards,
    Kral
    Kral&Stoikov,
    Imagine the following situation: a speedy A2D/D2A input/output connected to an 100MHz bus.
    The A2D/D2A analogic ground is also a RF ground for some transcievers running at 2.5Ghz and 5Ghz.
    The 100MHz bus is connected with a 2GHz DSP.
    How do you separe the RF ground, the analogic ground and the digital ground ?
  16. #16
    Full Member level 4
    Join Date
    Nov 2005
    Posts
    236
    Points
    3,747
    Level
    14
    analogue and digital ground
    good and real example to think about,
  17. #17
    Join Date
    Mar 2005
    USA
    Posts
    1,326
    Points
    12,011
    Level
    26
    analog ground vs digital ground
    melc,
    I don't have a perfect solution, but here goes:
    Isolate the RF section with its own ground plane. Use heavy local bypassing to this isolated RF ground plane. Call this "Gnd 1"
    A/D chips often have separate Digital, Analog ground pins. These are indications of the internal chip functions. Manufacturers usually recommend that these two grounds be connected together as close to the chip as possible, and treated as an analog ground. Call this "Gnd 2"
    D/A chips almost never have separte grounds, so treat this ground as an analog ground also. If the currents for the A/D and D/A sections are small, they could share the same ground or ground plane. Call this "Gnd 3" This could also be an isolated ground plane.
    Call the digital ground for the DSP and its associated parts "Gnd 4". This could also be an isolated ground plane.
    Connect the 3 (or 4) grounds or ground planes together at one point only. This is ideally done at the common ground for the power supplies for the 3 (or 4) sections of the circuit.
    Use adequate supply bypassing for all 3 (or 4) sections.
    Regards,
    Kral
