+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 460, Level: 4
    Join Date
    May 2012
    Posts
    113
    Points
    460
    Level
    Need information about these kind of high power leds.
    Click image for larger version.
    Hi guys. I am in the process of making a led bar lamp that uses these high power leds (10w each!). By the way, they do cost around $1 each one, very cheap!
    I need to know if these leds do need a resistor in series, or if I should connect it directly to the 12V. They do work with 12V, but I have no information about if they do need a resistor, just like all the regular leds. Thanks.
    Here I put the specs
    - LED Emitter: 10W
    - Output Lumens: 900 Lumens
    - DC Forward Voltage (VF) :9-12 V DC
    - DC Forward Currect (IF) : 900mA
    - Color Temp: 5500 ~6200K (CoolWhite)
    - Beam Angle: 140 degrees
    - LifeSpan Time : > 50,000 hours
    •   Alt15th December 2012, 10:57
      advertising
  2. #2
    Super Moderator
    Points: 69,588, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,375
    Points
    69,588
    Level
    64
    Re: Need information about these kind of high power leds.
    They need a resistor or even better, constant current source. If you connect 12V directly across them they will almost certainly die very quickly!
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
