Problem with Proteus ... Square Wave Generator Example
MAAASD
Member level 4
Problem with Proteus ... Triangular Wave Generator Example
Hello all,
I've designed a square wave generator on proteus and i want to check its output on the
virtual graphic mode but it seems i've a problem with the design itself
I got this error "Singular Matrix : check node ....."
here is the simulation file
View attachment Triangular_wave1.zip
Your help is much appreciated :)
It's a Triangular wave not square wave sorry :)
  • Triangular_wave1.zip
hello again,
I still need your help :)
I'm trying to simulate the same type of triangular wave generator in Proteus and it fails to find a solution for the circuit, as well.
