how much are it default value of enumeration in vhdl?
taoshen
Junior Member level 1
example:
type multypes is (none, iterative, m32x8, m16x16, m32x16, m32x32)
value of none is 0 , 00, or 000 ?
value of iterative is 01, 001 or 0001?
It depends on the synthesis mode: one-hot or etc. If onehot has been selected, "none" is synthesized to -----1. Otherwise it will synthesize to 0, "iterative" to 1 and etc. You also can specify the value of them, i.e. (none=0, ...).
Regards,
KH
how to decid the synthese mode?
Synthesis mode is one of switches in the synthesis tools and you as a designer can change it. For example in Leonardo, after selecting Tools --> Synthesis Wizard --> Next, you will see "encoding Style" when you read input files. Its default value is "Auto" which can be set to "Binary", "Onehot", "Twohot", "Random" and "Gray".
Regards,
KH
