+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 29
  1. #1
    Advanced Member level 2
    Points: 3,339, Level: 13
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    PIC12F683 mikro c pro code ADC
    Please let me know that I wrotw this attached code for ADC 10 bit but its not working another question is that how to implement Frc bit of ANSEL register.
    IMRAN
  2. #2
    Banned
    Points: 6,265, Level: 18
    Join Date
    Jul 2012
    Posts
    1,192
    Points
    6,265
    Level
    18
    Re: PIC12F683 mikro c pro code ADC
    How can you assign a integer value ( of 10-bit ADC value) to an o/p pin which is a bit. will a bit o/p a integer value?
    your code
     unsigned int temp_res;
    void main() {
      ADCON0=0x83;
      ANSEL  = 0x01;
      TRISIO  = 0x09;
      CMCON0=0x00;
      do {
        temp_res = ADC_Read(0);
        GPIO.GP1 = temp_res;
      } while(1);
    is wrong. Try to display the value of temp_res by using lcd or some other thing.
    1 members found this post helpful.
  3. #3
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    What are you trying to do?
    Here's your code:
    void main() {
      ADCON0=0x83;
      ANSEL  = 0x01;
      TRISIO  = 0x09;
      CMCON0=0x00;
      do {
      } while(1);
    Whatever settings you have in ADCON0 will be overwritten by the ADC_Read() function. So, setting ADCON0 doesn't really do anything.
    temp_res gets the ADC reading value. But what are you trying to do with it? You can't just send it to a single output pin.
    Here's the ANSEL register:
    As you can see, to set FRC, you have to use 011 or 111 for ADCS2:ADCS0 (ADCS[2:0]). I think mikroC automatically initializes the ADC to use FRC.
    Hope this helps.
    Tahmid.
  4. #4
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    So,what should I will do for displaying AN0 input analog value on any single port like GP1-GP5.
    I want to show analog input value in any port GP1-GP5 except GP3.
    IMRAN
    •   Alt18th November 2012, 17:29
      advertising
  5. #5
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    So, you want the output to be 4-bit and displayed on GP5, GP4, GP2, GP1.
    The ADC result is a 10-bit value. You need to turn it into 4-bit.
    So, try this:
    unsigned char tres;
    void main() {
      ANSEL  = 0x01;
      TRISIO  = 0x09;
      CMCON0=0x00;
      do {
        temp_res = ADC_Read(0) >> 6;
        tres = temp_res;
        GP5_bit = tres >> 3;
        GP4_bit = (tres & 0x04) >> 2;
        GP2_bit = (tres & 0x02) >> 1;
        GP1_bit = tres & 0x01;
        delay_ms(100);
      } while(1);
    Hope this helps.
    Tahmid.
  6. #6
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    Its a conversion of 10-bit to 4-bit but i saw PIC12f683 based voltmeter, in that circuit the 10-bit values transmit serially by single bit.So how he implement transmission data on single bit.
    IMRAN
  7. #7
    Banned
    Join Date
    Jul 2012
    Posts
    1,192
    Points
    6,265
    Level
    18
    See this link, there is some code http://www.electronics-lab.com/proje...015/index.html
    Are you using Internal Oscillator? if yes, what is the frequency of clock and have you set to use internal osc function and IO function on GPIO4 and GPIO5?
  8. #8
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Notice that there is an additional chip used - 74HC595. It is a serial shift register. Go through the datasheet: www.nxp.com/documents/data_sheet/74HC_HCT595.pdf
  9. #9
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    Yes i m using internal oscillator at 4Mhz (INOSCIO) .
    Do you have any knowledge about automotive electronics like Engine Control Unit (ECU) data transmission .
    ooh yes its ok.Do you have know any IC for converting serial data into 7-segment display.
    I know one IC but its available in market
    IC number is MAX7219.
    IMRAN
    •   Alt19th November 2012, 15:05
      advertising
  10. #10
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Do you actually mean that the IC is not available in the market? If it is available in the market, you should use it. It's a nice chip and you can easily interface it with the 12F683 using SPI.
    •   Alt19th November 2012, 15:28
      advertising
  11. #11
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    Yes its not available in the market sorry for mistake.
    IMRAN
  12. #12
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    If I want to purchase MAX7219 in Bangladesh by internet what would I do?
    IMRAN
  13. #13
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Why do you want to purchase it from Bangladesh? Can't you get it at all from Karachi?
    If availability is such a big issue, don't use MAX7219. Instead use a larger PIC, where you'll have enough pins to drive the 7 Segment directly from the PIC. PIC16F877A is a common PIC that I'm sure you can get hold of.
  14. #14
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    Its ok.PIC16F877A is a common PIC.I am newer in PIC and learning please do have any LCD code by using SPI.
    IMRAN
  15. #15
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    MAX7219 is available here in Lahore for Rs.250, then why can't you find it in Karachi.
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
  16. #16
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Quote Originally Posted by imranahmed View Post
    You can connect the LCD directly to PIC, without the need to use SPI. The PIC16F877A has enough pins. Is there any specific reason you want to use SPI for LCD?
  17. #17
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    In electronic market, the price of MAX7219 is 550 rupees is much more price and according to you in its price is only 250Rs.
    Can I buy this IC in 550Rs.????
    I want that the any received data by serially is display on LCD.What can i do?
    IMRAN
    •   Alt22nd November 2012, 16:25
      advertising
  18. #18
    Achievements:
    Tahmid's Avatar
    Join Date
    Jun 2008
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    Do you mean you want to display data that is received by serial communication, eg SPI or UART, on the LCD?
  19. #19
    Banned
    Join Date
    Jul 2012
    Posts
    1,192
    Points
    6,265
    Level
    18
  20. #20
    imranahmed's Avatar
    Join Date
    Dec 2011
    Karachi,Pakistan
    Posts
    583
    Points
    3,339
    Level
    13
    Yes exactly.
    IMRAN
