+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 4
    Points: 610, Level: 5
    Join Date
    Dec 2011
    Posts
    77
    Points
    610
    Level
    Relationship between carrier frequency and the bandwidth of the system?
    I have some basic doubts in communication. I got this while I was reading about Optical Communication. It states that "The higher the carrier frequency, higher is the bandwidth of the system."
    How can you say that?
    Also
    It states that optical communication has higher bandwidth when compared to normal communication using RF.
    Plz help me with this confusion
    Thanks a lot :)
    •   Alt17th November 2012, 08:41
      advertising
  2. #2
    Full Member level 1
    Points: 1,795, Level: 9
    Achievements:
    7 years registered
    Join Date
    Dec 2008
    Scotland
    Posts
    118
    Points
    1,795
    Level
    9
    Re: Relationship between carrier frequency and the bandwidth of the system?
    I don't agree with that publication. Bandwidth of RF or optical communication depends on the type and frequencies of the modulation used. An unmodulated carrier, at any frequency, has no bandwidth.
    •   Alt17th November 2012, 11:50
      advertising
  3. #3
    Member level 1
    Points: 1,505, Level: 8
    Achievements:
    7 years registered
    Join Date
    Oct 2010
    Posts
    34
    Points
    1,505
    Level
    8
    It would make more sense if instead: "The higher the carrier frequency, higher is the bandwidth of the system." it said "The higher the modulating frequency, higher is the bandwidth of the system."
    Optical communication has higher bandwidth simply because there is more "space" in frequency spectrum. In optical domain you are using frequencies of order 10^14 Hz compared to RF frequencies, let's say 10^6 - 10^9 Hz
    •   Alt17th November 2012, 12:41
      advertising
  4. #4
    Super Moderator
    Points: 239,549, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,502
    Points
    239,549
    Level
    100
    Yes, I think the original post is asking about this trivial fact. More exactly, we should say: potentially higher bandwidth, if the modulation method allows it.
  5. #5
    Full Member level 6
    Points: 4,399, Level: 15
    Join Date
    Jul 2004
    Posts
    333
    Points
    4,399
    Level
    15
    In terms of data communications bandwidth is bits/sec that the system can transmit.
    I think that a higher carrier can be modulated by a higher frequency and thus achieving more symbol rate. So the statement is true. The frequency bandwidth occupied by the channel will be wider.
    Please disregard my previous post.
