+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 515, Level: 4
    Join Date
    Jan 2011
    Posts
    20
    Points
    515
    Level
    4-20mA Current Loop isolator deign
    hi all
    I want to design a circuit that has an input of 4-20 mA(loop power) and 4-20 mA output with input and output isolation
    •   Alt13th October 2012, 23:37
      advertising
  2. #2
    Administrator
    Points: 37,998, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
    Re: 4-20mA Current Loop isolator deign
    You could achieve that using www.vishay.com/docs/83622/il300.pdf
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
    •   Alt13th October 2012, 23:57
      advertising
  3. #3
    Join Date
    Jan 2011
    Posts
    20
    Points
    515
    Level
    How do I design a circuit 4-20 mA loop power with IL300
    input 4-20ma loop power
    output 4-20ma isolat
    thanks
    •   Alt14th October 2012, 16:14
      advertising
  4. #4
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
    I believe that this is your task, I'm not going to provide you a ready circuit, I have just pointed you to a component you can use to achieve what you want.
    Check the datasheet example and modify it to your needs.
