+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 3
    Points: 436, Level: 4
    Join Date
    Oct 2012
    Posts
    Points
    436
    Level
    1 second interrupt using timer0
    hi,
    i m new to pic programming.i used an example code in mikroC time calculator to make a 1 second interrupt. the problem is when i simulate it in protues, i can see that led blinking time is more than 1 second.why is that??
    pls help
    thanks.
    this is the code
    [syntax=c]//Timer interrupt: 25 ms
    //Desired Interrupt Time: 2.5 s
    //cnt value: 100 (2.5 s / 0.025 s)
    //MCU: PIC 16F887
    //Internal module: Timer0
    //Prescaler 1:256; TMR0 Preload = 61; Actual Interrupt Time = 24.96 ms
    unsigned cnt; // This is the counter variable which will extend desired period
    void InitTimer0(){
    OPTION_REG = 0x87; // Prescaler 256
    TMR0 = 61;
    INTCON = 0xA0;
    void Interrupt(){
    if (TMR0IF_bit){
    cnt++; // Increment counter, this is the tweak we added in original Timer Calculator code
    TMR0IF_bit = 0; // Clear TMR0IF
    TMR0 = 61; // Prepare for next interrupt
    void main() {
    InitTimer0(); // Initialize Timer0
    ANSEL = 0; // Configure AN pins as digital
    ANSELH = 0;
    C1ON_bit = 0; // Disable comparators
    C2ON_bit = 0;
    TRISB = 0; // PORTB is output
    PORTB = 0xFF; // Initialize PORTB
    cnt = 0; // Initialize cnt
    do {
    if (cnt >= 40) { // 1s
    PORTB = ~PORTB; // Toggle PORTB LEDs
    cnt = 0; // Reset cnt
    } while(1);
    }[/syntax]
    •   Alt13th October 2012, 22:49
      advertising
  2. #2
    Full Member level 5
    Points: 1,942, Level: 10
    Join Date
    Apr 2012
    bangalore
    Posts
    311
    Points
    1,942
    Level
    10
    Re: 1 second interrupt using timer0
    have u burnt the code on the PIC microcontroller
    •   Alt14th October 2012, 10:47
      advertising
  3. #3
    Advanced Member level 5
    Points: 38,206, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,206
    Level
    47
    Blog Entries
    22
    The program generates a "1 second interrupt" if the PIC is running at 8MHz. Maybe you have not set the PIC clock frequency as 8MHz in Proteus. If you haven't, set the PIC clock frequency as 8MHz.
