+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Junior Member level 1
    Points: 1,687, Level: 9
    Join Date
    Jan 2004
    Posts
    19
    Points
    1,687
    Level
    9
    uvlo circuit
    If there is no Zener diode devices,How to design undervoltage lockout circuits?
    Best regards,
    •   Alt8th November 2004, 14:54
      advertising
  2. #2
    Advanced Member level 1
    Points: 4,904, Level: 16
    Join Date
    Mar 2002
    Posts
    447
    Points
    4,904
    Level
    16
    most times uvlo simply uses a comparator with a little hysteresis. VDD is divided down (say in half), and compared to the bandgap voltage. (Say 1.25v) Now your uvlo trips when VDD = 2Vbg or 2.5v. There ya go.
    Do you have a bandgap? If not it's a little trickier..
  3. #3
    Full Member level 5
    Points: 2,541, Level: 11
    Join Date
    Oct 2004
    Posts
    307
    Points
    2,541
    Level
    11
    I also suggest you use a simple comparator .use devided Vdd compared with a stable reference.it must need a reference voltage.
  4. #4
    Join Date
    Mar 2002
    Posts
    447
    Points
    4,904
    Level
    16
    under voltage lockout circuit
    qutang - please don't repeat answers, or post junk. it really bothers me.
    •   Alt9th November 2004, 18:26
      advertising
  5. #5
    Full Member level 5
    Points: 3,494, Level: 13
    Join Date
    Apr 2004
    USA
    Posts
    251
    Points
    3,494
    Level
    13
    Quote Originally Posted by electronrancher
    Hi, what if the supply voltage drops to a level that both bandgap and comparator are not able to work, at this moment, the output signal is uncertain, it will be 0.6v or something like that, so how to make sure when VDD drops (under 2Vbg in your case), the UVLO circuit can give a reliable 0V output? Thanks.
    •   Alt7th December 2004, 02:26
      advertising
  6. #6
    Advanced Member level 3
    Points: 7,066, Level: 20
    Join Date
    May 2004
    Posts
    874
    Points
    7,066
    Level
    20
    undervoltage lockout ic
    hi,cmosbjt
    you can use pull up Res to fit your request
  7. #7
    Points: 1,502, Level: 8
    Join Date
    Nov 2004
    Istanbul,Turkey
    Posts
    16
    Points
    1,502
    Level
    8
    circuit under voltage lockout
    you need a "UNDERVOLTAGE SENSING CIRCUIT". you could use an IC like MC34064. i advise you to check spec sheet of MC34064.
    -Erkan
  8. #8
    Member level 1
    Points: 1,657, Level: 9
    kawaiicat's Avatar
    Join Date
    Dec 2004
    Posts
    32
    Points
    1,657
    Level
    9
    under voltage lock out
    how can i do if for high voltage?if i dont' want to waste so much current the voltage divided, another method?as long as i don't want to draw a big resistor in my IC also
    thanks
  9. #9
    Join Date
    Mar 2002
    Posts
    447
    Points
    4,904
    Level
    16
    under voltage circuit
    up to about 12v, i usually see resistor dividers of a few hundred k. other alternative is if you have an internal regulated supply voltage, do uvlo on that rather than on the input.
    what is your uvlo voltage you want?
  10. #10
    Full Member level 1
    Points: 2,029, Level: 10
    Join Date
    Feb 2005
    Singapore
    Posts
    104
    Points
    2,029
    Level
    10
    12v undervoltage ic
    I don't see how you can do away with some form of potential divider. it can be resistor/mos. use natural mos for higher thresholds.
    •   Alt17th February 2005, 07:38
      advertising
  11. #11
    Full Member level 2
    Points: 2,117, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2007
    India
    Posts
    141
    Points
    2,117
    Level
    10
    supply undervoltage design
    How can i include hysteresis?
    Is it sufficient to introduce hysteresis in comparator? or i have to introduce it externally?
    If externally, how to include it?
  12. #12
    Points: 1,890, Level: 10
    Join Date
    Oct 2005
    Norfolk uk
    Posts
    Points
    1,890
    Level
    10
    Re: Looking for undervoltage lockout circuits!
