Net book Dell inspiron Mini 1018 doesn't boot automatically ..need to be select ?
thannara123
Advanced Member level 5
India
Hello experts ,
I am now facing a problem with my Net book Dell inspiron Mini 1018 dosenot boot automatically ..need to be select Boot option (Hard disk)
How can i solve this problem ?
Re: Net book Dell inspiron Mini 1018 dosenot boot automatically ..need to be select ?
Make sure that the HDD is selected as the default boot device in the BIOS.
Also check the battery line and supply line
Do see if the SMPS fan is running
If they are then the fault is in your boot setup only just edit them in the setup
I can simply login to desktop but need to boot press any key or need to select boot option .All are working properly .
I cant update the BIOS due to the same version cant burn !
u can select first boot device form bios to hard disk
Yes it is hard disk (first boot device )
