+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
  1. #1
    Advanced Member level 1
    Points: 2,341, Level: 11
    Join Date
    Aug 2011
    Posts
    428
    Points
    2,341
    Level
    11
    Difference between AC Voltage Stabilizer & AC Voltage Regulator?
    Difference between AC Voltage Stabilizer & AC Voltage Regulator ?
  2. #2
    Advanced Member level 5
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    Re: Difference between AC Voltage Stabilizer & AC Voltage Regulator ?
    I don't believe there is a specified difference. Where I used to work, stabilizers were based on saturated inductors, power up to 1kW . Voltage regulators (AVRs - Automatic Voltage Regulators) were based on motor driven rotary transformers, power up to 250 kW.
    Frank
  3. #3
    Join Date
    Aug 2011
    Posts
    428
    Points
    2,341
    Level
    11
    the stabilizers that i have got have a transformer , 4 to 5 electro mechanical relays , pots are there with each of the relays to adjust the gain ...... and some little circuitry having zener diodes and resistors, capacitors and few transistors (normal NPN type) .....
  4. #4
    Points: 10,418, Level: 24
    Join Date
    Sep 2001
    Argentina
    Posts
    1,131
    Points
    10,418
    Level
    24
    If i'm not wrong, the distinction is:
    Stabilizer: output voltage does not change (ideally) if input votage varies. But output can change if load current changes. Works in open loop (voltage output is not sensed).
    Regulator: output voltage is mantained constant if input voltage OR load current change. Works in closed loop (voltage output is sensed).
    Regards
    Z
  5. #5
    Full Member level 5
    Points: 1,591, Level: 9
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    chuckey is right or zorro is right ?
    •   Alt1st October 2012, 20:07
      advertising
  6. #6
    Member level 4
    Points: 2,070, Level: 10
    Achievements:
    7 years registered
    Join Date
    Oct 2008
    Uttar pradesh (INDIA)
    Posts
    77
    Points
    2,070
    Level
    10
    Dear Dinesh,
    talking in Indian market context..here both of these terms refers to a device which controls the ac voltage fluctuation up to some defined limits and outputs a stable ac voltages within a specified output voltage window ( this window depends on the design itself).. these both terms are sometimes used interchangeably for same stuff..but YES there exists two different type of technologies for AC VOLTAGE STABILIZER or AC VOLTAGE REGULATOR... both of these technologies has there pros and cons in terms of cost and performance ...
    There are two types of them one with a auto transformer with several winding taps connected to relays..these types are switches relays in certain combination so that out put remains at some defined window/limit.. here the output is specified to go +- few percentage of rated out put voltages..for example a unit with rated output voltages of 220 VAC will vary by a percentage value as specified by the manufacturer..generally this variation is +-9% ( note that this ouput variation will be over full input VAC range...range may be 140-285 VAC or 110-285 VAC )..
    The other type is a design with a auto-transformer wound in VARIC shape..and a central shaft which moves a ARM ( having a conductor at outer edge) over the edges of this VARIAC.. this shaft is connected to a Motor ..and this motor is again governed by a circuitry which commands it to move clock/anticlockwise directions to compensate/buck/boost the output of auto transformer... these types of designs usually have tighter output voltage regulation.. even 1 % is possible..These types are generally called as SERVO VOLTAGE STABILIZERS.
    Hope the above explanations will clear your doubts.. ... i kept the explanation simpler as much as i can..
  7. #7
    Member level 4
    Points: 1,339, Level: 8
    Join Date
    Sep 2012
    Nigeria
    Posts
    78
    Points
    1,339
    Level
    8
    They are the same .They made up of auto-transformer of different voltage output ,switching device,The control cct is made of voltage comperators.They are also input voltage range which on the transformer design.
    They are the same .They made up of auto-transformer ,switching device,The control cct is made of voltage comperators.They are also have input voltage range which depend on the transformer design.
    "Let love lead and the greatest investment in world is HELP"
  8. #8
    Join Date
    Aug 2011
    Posts
    428
    Points
    2,341
    Level
    11
    can we use servo voltage stabilizers on any device ? on computers and also with other loads whether refrigerators , tVs , deep freezers , split A.Cs etc .....
    •   Alt2nd October 2012, 16:59
      advertising
  9. #9
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Oct 2008
    Posts
    77
    Points
    2,070
    Level
    10
    Quote Originally Posted by danishdeshmuk View Post
    YES you can..in fact relay type voltage stabilizers are only common for power ratings up to few KW of power..generally maximum upto 10 Kw...but servos stabilizers are comes in power rating up to many hundreds of Kw...
    •   Alt2nd October 2012, 17:47
      advertising
  10. #10
    Points: 5,757, Level: 18
    Join Date
    Jul 2012
    chennai,india
    Posts
    1,094
    Points
    5,757
    Level
    18
    Blog Entries
    Stabiliser does this it either gives a stable output or breaks the circuit if the voltage drop is too high or low
    The regulator is bit different in its response to that of the stabiliser
    JEFFREY SAMUEL
    A man in another realm always
    PM ing me will not solve any of your problems I can assure you that
    Thanks for the co operation
  11. #11
    Join Date
    Dec 2010
    Posts
    4,863
    Points
    25,337
    Level
    38
    Quote Originally Posted by jeffrey samuel View Post
    No the AC output just carries on with its voltage at the point when the stabilizer gave up. i.e. if the incoming mains should be 230V (100%), the stabilizer should hold it correct for a 90% value (207 in, 230 out), if the input falls to 190 V, the output would be 211V.
    Our motor driven variacs would hold .25% for a +- 10% input, though they took a second to get there. There are also moving coil regulators we had one rated at 500kW, this was motor driven as well.
    Frank
  12. #12
    Full Member level 5
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    but here in india , they say that you can use servo stabilizers only for computers not for other inductive loads ..... like refrigerators, freezers , A.Cs , split A.Cs , TV etc
  13. #13
    Join Date
    Dec 2010
    Posts
    4,863
    Points
    25,337
    Level
    38
    You can say what you like in India. its a democracy, does not mean its correct though.
    Frank
  14. #14
    Join Date
    Jul 2012
    chennai,india
    Posts
    1,094
    Points
    5,757
    Level
    18
    Blog Entries
    Hello Frank
    this is a forum
    Anyways if it is a Stabiliser it can be used for any equipment
    I seriously doubt it to be so
    Dear Danish
    Can you post some model specifications of what ever you have in your concern
    JEFFREY SAMUEL
  15. #15
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Oct 2008
    Posts
    77
    Points
    2,070
    Level
    10
    Quote Originally Posted by dineshdeshmuk View Post
    No..that was true few years back when a device popularly known as "CVT"( Constant Voltage Transformer) was used as a pre-mains regulator to provide clean and regulated output to PCs... those were very accurate with only a fraction of a percent output variation over full rated operating mains input range..but at the same time they were very bulky and there input mains operating range was also very narrow just from 145-160 VAC ~ 285 VAC ac mains input...there output voltage regulation was based on principle of "Magnetic Resonance"..a transformer/capacitor pair was used..and this employed priciple itself was responsible for there not working well on Inductive load...later on these CVTs were replaced by relay based so called AVRs(Automatic Voltage Regulator)..these AVRs are now a standard feature of small UPS systems meant for powering home- SOHO segment PCs...
    Infact they were so bulkier in size that today you can compare a present day 5KVA stabilizer transformer with just a 500 VA transformer of a CVT...
  16. #16
    Join Date
    Aug 2011
    Posts
    428
    Points
    2,341
    Level
    11
    but aashitech , i am talking about the servo stabilizers ..... the term CVT was for servo stabilizers ?
    How to figure out that the servo stabilizer that i have got is not a CVT based OR its an AVR based , how to find that out ?
  17. #17
    Full Member level 5
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    Quote Originally Posted by chuckey View Post
    Frank
    just tell me whether its right or wrong : can use servo stabilizers only for computers not for other inductive loads ..... like refrigerators, freezers , A.Cs , split A.Cs , TV etc ??
  18. #18
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Oct 2008
    Posts
    77
    Points
    2,070
    Level
    10
    Dear,
    The unit with relays connected to many taps of auto transformer is generally what we call as "Stabilizer"
    ..present days servos are made up of a variac(s) connected to a motor through a shaft..this motor is under control of a control circuitry ( usually SCRs are used as switches to energize motor..and control circuitry itself may be designed around simple comparators or an MCU).
    To identify a CVT ..open it and look for one transformer with split windings on split bobbin..and in some manner a big capacitor or two are connected to this transformer...chances of any relays ( for any additional auxiliary feature) are rare...
  19. #19
    Full Member level 5
    Join Date
    Sep 2011
    Posts
    285
    Points
    1,591
    Level
    9
    ok if there are couple of big capacitors with a big transformer means its a servo stabilizer having CVT design and if there are relays , SCRs etc with a transformer then it means its a servo stabilizer having AVR stup which is the modern technique of controlling the voltage automatically for any kind and for any type of load , Right ???
  20. #20
    Member level 4
    Achievements:
    7 years registered
    Join Date
    Oct 2008
    Posts
    77
    Points
    2,070
    Level
    10
    NO NO..I think you are not reading my posts with great attention....
    (1) Transformer + Relays = Voltage Stabilizer.
    (2) Variac + motor + circuitry = Servo Stabilizer.
    (3) Transformer with Split Winding on split Bobbin + big capacitors = CVT.
    Yes for household application Voltage Stabilizer ( remember that relay one) is ok... and for all purpose including house hold Servos are good.
    1 members found this post helpful.
    •   Alt4th October 2012, 21:03
      advertising
