+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Full Member level 1
    Points: 1,402, Level: 8
    Join Date
    May 2011
    india
    Posts
    106
    Points
    1,402
    Level
    8
    circuit diagram for 24V 6A dc smps to 5v 9A dc converter
    dear all please send me circuit diagram for it
    •   Alt22nd September 2012, 17:18
      advertising
  2. #2
    Super Moderator
    Points: 47,089, Level: 53
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,749
    Points
    47,089
    Level
    53
    Re: circuit diagram for 24V 6A dc smps to 5v 9A dc converter
    A dual interleaved buck converter could be suitable.
    Schematic of my simulation:
    The switches must be replaced by mosfets/transistors. Component values are theoretical and can be changed.
    A single buck converter will not give you 9A. It only provides as much current as is available from the supply (that is, 6A).
    Another type is transformer based (flyback). I had a simulation going, and I tried to make a transformer which provides 5V to the load. I have not succeeded. (Sending pulsed DC through a transformer gets tricky.)
  3. #3
    Advanced Member level 5
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hi Prashanttiyagi
    As Bradtherad said one of the best solutions is a buck converter . but there is another way available too . i think with this low voltage , you don't need any isolation , so a simple flyback converter , with non isolated feedback ( with two resistors and a common ground ) can be ok too .
    But another thing , if you use a buck converter in discontinuous mode , out put current can be higher than input current .
    Best Wishes
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
    •   Alt22nd September 2012, 23:18
      advertising
  4. #4
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,749
    Points
    47,089
    Level
    53
    I managed to devise a simple flyback converter (simulated) that provides 5V at 9A.
    Schematic:
    Values are theoretical and can be changed.
    The diode needs to be oriented at whatever polarity works best.
    1 members found this post helpful.
  5. #5
    Full Member level 1
    Join Date
    May 2011
    india
    Posts
    106
    Points
    1,402
    Level
    8
    thanks to all for this
    but i told that i am new for this field
    so please help me by sending some links or data for basic knowledge of these kind of supply
  6. #6
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,749
    Points
    47,089
    Level
    53
    Your thread title suggests there is already a switch mode power supply creating the 24V 6A.
    Rather than add another smps, it might be practical to adjust the incoming supply to your desired spec.
    I don't know that it is possible. However if it could be done then you can save some work and expense.
    Furthermore even if you start building your own smps, it may turn out to be impractical.
    •   Alt24th September 2012, 13:42
      advertising
  7. #7
    Achievements:
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Hi again , if you are new , at this , process , i think you'd better to take a look at datasheet of UC3845 . it will be interesting ! then i think we can guide you more .
    Best Wishes
    Goldsmith
