problem while uploading arduino sketch in arduino uno r3 using arduino 1.0 ide
kunal123
mumbai
hello,
i facing problen while uploading sketch in arduino uno r3 using arduino1.0 IDE, uploading complete i get Done uploading with following message
System wide configuration file is "C:\Users\kunalk\Desktop\arduino\arduino-1.0-windows\arduino-1.0\hardware/tools/avr/etc/avrdude.conf"
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude done. Thank you.
can someone suggest me solution for these error
thanks
This will happen because of two reasons basically
1. if the COM port that is selected is wrong.
2. if the arduino has no driver installed ( go to control panel , device manager, and you will find unidentified device then right click and press update to get it working.
regards
bala krishna
