+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 2
    Points: 50, Level: 1
    Join Date
    Sep 2012
    Posts
    Points
    50
    Level
    Altium Designer : how to change default net name in schematic editor
    Hello, i need a net list with net names different than default net name given by Altium Designer (6.0), that in my case is Net#####.
    I can't assign Net aliases to all wires and i would like to find a way to change this name in way as much immediate as possible. For example i need to assign the name from Net#### to N#####.
    These are the attempts i made so far:
    - selected all wires and tried to change the net name from "List" and "Inspector" tools -> i can see no column that allows me to do that
    - used Parameter Manager / Nets -> i can see the column "Identifier" but cannot edit the content
    - tried to set a value in schematic preferences for wires -> there's no field regarding the name. Making the same things for Net name primitives it only sets the default name to put when you place a net name but all the "un-named" wires wont be named with that pattern
    - it would be possible to rename nets through the list tool in pcb design -> in my case pcb wont be made by Altium, that's why i need a correct netlist to be managed by other pcb tools
    Please let me know if something is not enough undertandable.
    Fabrizio.
    •   Alt19th September 2012, 08:12
      advertising
  2. #2
    Full Member level 5
    Points: 3,114, Level: 13
    loosemoose's Avatar
    Join Date
    Dec 2008
    Vancouver, BC
    Posts
    319
    Points
    3,114
    Level
    13
    Re: Altium Designer : how to change default net name in schematic editor
    the only way no assign a net name in Altium is to place a net label. But you would have to do this for every net.
    You could generate a netlist in text format from your schematics and then use a text editor to globally change the names.
    •   Alt19th September 2012, 19:44
      advertising
  3. #3
    Newbie level 2
    Join Date
    Sep 2012
    Posts
    Points
    50
    Level
    Thank you for replying.
    Actually i would avoid to do what you suggested cause that would mean doing it everytime i edit the schematic.
    I really cant understand why they didnt allowed to set a default name different than theirs, or at least consider to name a wire but hide the label as it was a parameter like components have.
    Anyway thank you again.
