ravi8820
Junior Member level 1
Sir,
I am trying to connect an "ATMEGA 16A microcontroller" (which is impressed in a development board) with a "USB AVR programmer" by connecting through their isp header pins. I had connected them correctly using connecting wires. After that for checking whether i had connected them correctly or not i had written
"avrdude -c usbtiny -p m16" in the command prompt.
Then it is giving the error writing
"avrdude: error: programm enable: target doesn’t answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you."
What are the possible causes of this error and how can i rectify those errors so that i can start my programming in a smooth way. Please help me in this regard.
this check.
