TCL "exec" command problem in SoC Encounter in Debian 6
soloktanjung
Full Member level 6
nowhere
I am trying to run my TCL script which has "exec" command calling another shell script in Debian 6. But the SoC Encounter 10.1 terminal gives an error (child killed: segmentation fault) whenever it reach the "exec" command in the TCL script. I have run the same TCL script in same version of SoC Encounter (10.1) in the Debian 5 without any problem.
Does anyone has met the same problem? or could anyone pointed me what would be the cause?
Thanks.
hai hairo
I am using soc encounter same version
Instead of "exec"
avoid using exec
just try with that command
or use [ ] instead of exec.
may work...
I'm sorry but I dont understand your suggestion. Should I try to use [] instead of "exec"? how is that?
Thanks.
Re: TCL "exec" command problem in SoC Encounter in Debian 6
if u want to execute a thing u can specify within braces.. It will suit for some commands u can try..
EX:-
[length $a]
give ur command inside []..
If it not works... give the specific command that u need in tcl.. i will try and report if there is any optional way..
