+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 6
    Points: 2,277, Level: 11
    thebadtall's Avatar
    Join Date
    May 2012
    Hellas
    Posts
    338
    Points
    2,277
    Level
    11
    dc dc converter 12v to 180v
    Hello !
    I would like to make a dc dc converter ,(without to use coil or choke or something like that) in order to get the necessary voltage (180v )to run a "magic eye" tube, on a vu meter circuit. (and some nixie tubes on other circuit )
    this circuit runs fine with back to back transformers and has a range of 150 to 250vdc, but i would like to know how i could replace those back to back transformers with a smps 12v/1(or 2) A and a dc dc circuit.
    I need about 100ma !
    thank you !
    ..the child bless thee and keep thee forever
    •   Alt4th September 2012, 13:26
      advertising
  2. #2
    Advanced Member level 2
    Points: 3,328, Level: 13
    Genovator's Avatar
    Join Date
    Dec 2011
    India
    Posts
    546
    Points
    3,328
    Level
    13
    Blog Entries
    Re: dc dc converter 12v to 180v
    As I know, converting 12 v DC to 180 v DV would be very less efficient. Still only one Idea I am having right now is to first convert dc to ac by this...
    And then use voltage multiplier circuit (atleast 15 diodes for 12v x 15 = 180v) like this...
    again converting it into dc....
    Hope you get any better idea......
    Wading all day.....
  3. #3
    Full Member level 6
    thebadtall's Avatar
    Join Date
    May 2012
    Hellas
    Posts
    338
    Points
    2,277
    Level
    11
    aha, good idea to use the cascade voltage doubler! but is it going to handle around 15watts?
  4. #4
    Genovator's Avatar
    Join Date
    Dec 2011
    India
    Posts
    546
    Points
    3,328
    Level
    13
    Blog Entries
    If you drive 15 watt, then calculation says current drawn will be ~83ma. Current drawn is very low and as the circuit seems to be, I hope it should work. Since it is less efficient, let consider its efficiency to be as less as 40%. Then the source should have the capacity of around 25W. (With 12v constant voltage, current = ~2.08 or 2A). So check your source is capable to give such current.
    You can add one more diode to adjust the voltage drop by 15 diodes.
    All rough calculations, so I advise not to go with this. Make your own calculation for better accuracy.
    Wading all day.....
    •   Alt4th September 2012, 19:30
      advertising
  5. #5
    Full Member level 6
    thebadtall's Avatar
    Join Date
    May 2012
    Hellas
    Posts
    338
    Points
    2,277
    Level
    11
    good thank you!! do you know if i can use an ic?
  6. #6
    Super Moderator
    Points: 46,787, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,662
    Points
    46,787
    Level
    52
    As it turns out, a voltage multiplier could be more trouble than it's worth.
    This schematic is a Villard multiplier of several stages (enough to fill my screen width).
    You must start with 12 VAC. (It will barely work with pulsed DC.)
    It reaches 128 VDC output with a light load. It will require a few more stages to obtain your desired V.
    The diodes and capacitors must handle bursts of over 1 A during each cycle.
    1 members found this post helpful.
  7. #7
    Genovator's Avatar
    Join Date
    Dec 2011
    India
    Posts
    546
    Points
    3,328
    Level
    13
    Blog Entries
    Since you said you don't want to use coils or transformers, all other circuits will be complex and less efficient. I don't know any boost IC for 180V. All IC's known to me requires an external coil and are of low voltage output.
    Wading all day.....
    •   Alt5th September 2012, 14:17
      advertising
  8. #8
    Full Member level 6
    thebadtall's Avatar
    Join Date
    May 2012
    Hellas
    Posts
    338
    Points
    2,277
    Level
    11
    ok, i have some coils from dead psu. can i use those to manufacture an apropriate?
  9. #9
    Genovator's Avatar
    Join Date
    Dec 2011
    India
    Posts
    546
    Points
    3,328
    Level
    13
    Blog Entries
    Wading all day.....
