+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 6
    Points: 384, Level: 4
    Join Date
    Aug 2012
    Posts
    11
    Points
    384
    Level
    In what applications, low-Vth MOSFET and medium-Vth MOSFET are useful?
    Hi, all.
    Low-Vth MOSFET and medium-Vth MOSFET are provided by TSMC 0.18um CMOS process. but I never use them, all circuits I have designed apply standard-vth MOSFET.
    So I am very interested where low-Vth MOSFET and medium-Vth MOSFET are useful.
    Ziqi
    •   Alt1st September 2012, 15:17
      advertising
  2. #2
    Super Moderator
    Points: 50,710, Level: 55
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,975
    Points
    50,710
    Level
    55
    Re: In what applications, low-Vth MOSFET and medium-Vth MOSFET are useful?
    E.g. for MOS diodes in tail current sources, in order not to loose too much Vds .
    1 members found this post helpful.
  3. #3
    Points: 5,757, Level: 18
    Join Date
    Jul 2012
    chennai,india
    Posts
    1,094
    Points
    5,757
    Level
    18
    Blog Entries
    in places where the resistive drop across the MOS must be insignificant you go for low threshold
    JEFFREY SAMUEL
    A man in another realm always
    PM ing me will not solve any of your problems I can assure you that
    Thanks for the co operation
    •   Alt1st September 2012, 16:02
      advertising
  4. #4
    Newbie level 6
    Join Date
    Aug 2012
    Posts
    11
    Points
    384
    Level
    Quote Originally Posted by erikl View Post
    Quote Originally Posted by jeffrey samuel View Post
    I agree with you, both Erikl and Jeffrey. Although low-Vth MOSFET benefits low voltage drop, this technique is rarely introduced in textbooks or papers. So I suspect there are some drawbacks comparing with standard-Vth MOSFET. could you give me a sense?
  5. #5
    Join Date
    Jul 2012
    chennai,india
    Posts
    1,094
    Points
    5,757
    Level
    18
    Blog Entries
    each and every device has its own ups and downs based on the need served they are utilised by the public be it high low or standard ones
    books mostly use more prevalent form of any device as they are easier to understand and practically testing them in amateur state is easier and simpler
    low Vth devices the variations are very sensitive to voltage ip at mV levels that makes it not more popular for usage in labs and books for teaching newbies
    JEFFREY SAMUEL
  6. #6
    Member level 5
    Points: 938, Level: 6
    Join Date
    Jun 2012
    Bayreuth, Germany
    Posts
    82
    Points
    938
    Level
    If Vth is low then Vth mismatches will cause more drain current error.
  7. #7
    Join Date
    Jul 2012
    chennai,india
    Posts
    1,094
    Points
    5,757
    Level
    18
    Blog Entries
    Quote Originally Posted by KonstanU View Post
    yeah true
    in the case of low power MOS we use them as the low Vth is enough to keep the device in on state
    JEFFREY SAMUEL
    •   Alt2nd September 2012, 11:09
      advertising
  8. #8
    Super Moderator
    Achievements:
    7 years registered
    erikl's Avatar
    Join Date
    Sep 2008
    Germany
    Posts
    7,975
    Points
    50,710
    Level
    55
    Quote Originally Posted by Ziqi View Post
    ... So I suspect there are some drawbacks comparing with standard-Vth MOSFET. could you give me a sense?
    Low-Vth MOSFETs in "off" mode actually are still in weak inversion aka subthreshold mode, which means they have substantial leakage currents, considerably higher than standard-Vth MOSFETs.
    So in order to disable circuits for very low stand-by current consumption, they should only be used in series with standard-Vth MOSFETs, which can be disabled to small leakage currents. Hence low-Vth MOSFETs usually aren't left alone between GND & VDD, but as auxiliary devices for current sourcing/sinking with low Vds losses.
    If used as NMOS tail-current source for a degenerated differential NMOS stage, this has the advantage that only a low back-gate Vgb for the differential NMOS stage exists, so allowing for larger gm of this stage.
    2 members found this post helpful.
