power supply not working ? Direct 52 Vdc output not regulating ......
phatcreators
Full Member level 5
Having components :
L7812CV (Regulator)
L7805CV (Regulator)
E3055 (Transistor)
2 pieces of 2N3055 (power transistors)
No physical burning of any component , what component might gone bad ??
http://www.lightinthebox.com/Zhaoxi...y-For-Lab-PS-305D-H290408011750-_p106486.html
Product Name: ZHAOXIN RXN-605D Power Supply
Product Description:
Brand:ZHAOXIN
Model:RXN-605D
Origin:Shenzhen
Weight: 6KG
2 Digital Meter Display
■ Constant Voltage and Constant Current
■ High Effeciency,Small , Light Weight
■ High Power Density
■ Protective Function for Over-load and reverse polarity
Model RXN—602D RXN—603D RXN—605D
0-60V/2A 0-60V/3A 0-60V/5A
Constant Voltage Characteristics:
Voltage Regulation CV ≤0.01%+2mV ≤0.01%+2mV ≤0.01%+2mV
Loading Regulation CV ≤0.01%+2mV ≤0.01%+2mV ≤0.01%+2mV
Ripple and Noise CV ≤1mV(effective value) ≤1mV(effective value) ≤1mV(effective value)
Voltage Temperature Coefficient 150ppm/℃
Constant Current Characteristics:
Current Regulation CC≤0.2%+2mA
Load Regulation CC≤0.2%+5mA
Curent Temperature Coefficient 500ppm/℃
Ripple and Nouse CV ≤2mV(effective value)
Indicating Accuracy:
Disply: Digital Display Digital Display Digital Display
thanks
You should check output transistors first.
the power transistors (2N3055) ??? should test them first
i found it , one of the 2 power transistors gone bad ...... i checked it , tested it & replaced
by the way , which type of power supply is this ?
Constant current ?? , constant voltage ??? switch mode ????
The transistor that was bad has :
Base to Emitter Resistance : 155.6 ohms (for both forward bias & for reverse bias also)
Base to Collector : 168 ohms (for both forward bias & for reverse bias also)
Collector to Emitter : 14 ohms (for both forward bias & for reverse bias also)
I want to ask whether this transistor shorted or its become open , what problem it got ?
thanks
if your voltage 52V goes directly to your power supply output ..... its mean transistor has shortage if its will be open than you should have output voltage = 0
"open" usually means no connection in electronics.
This is a regulated voltage and constant current power supply as per the specification of the product. And as per the Product weight specified it seems to be containing a Transformer inside and not a Switching PS.
