+ Post New Thread
Results 1 to 14 of 14
  1. #1
    Junior Member level 2
    Points: 1,858, Level: 10
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Posts
    23
    Points
    1,858
    Level
    10
    Variable frequency generator using a 555 timer chip
    Hi
    i would like to make an frequency generator using a 555 timer chip. The frequency should vary in the range of 100hz to 1kHz with a reasonable duty cycle (20-80%). I am using the circuit below. Varying r2 alone would not do the job because at r2=0 the duty cycle is 100%.
    I found out if i started with r1=2k2 and r2=4k7 and c=1uF. The freq =124hz and duty cycle is 60%.
    At r1=700R r2=200R c=1uF. The freq=1309hz and the duty cycle is 81%.
    But i cant find a way to change both resistors with one potentiometer. Is there a way to do that or should i use a different topology?
    Thank you in advance
    Click image for larger version.
    •   Alt8th August 2012, 21:12
      advertising
  2. #2
    Advanced Member level 5
    Points: 11,015, Level: 25
    Join Date
    Apr 2012
    Posts
    1,981
    Points
    11,015
    Level
    25
    Re: Variable frequency generator using a 555 timer chip
    There is a simpler topology with only one resistor. It has a duty cycle close to 50%. See the changed picture below.
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,805
    Level
    52
    There are a few tricks you can try, to obtain a variable duty cycle. Some are at this link:
    http://www.elektrotekno.com/about49160.html
    One method uses a potentiometer dialing a position between two diodes arranged in anti-parallel.
    Another method uses a 556 dual timer IC. You select frequency with one 555 and the pulse length with the other.
  4. #4
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Posts
    23
    Points
    1,858
    Level
    10
    Quote Originally Posted by godfreyl View Post
    I am simulating this option and it does not seem to work. Shouldnt pin 7 be connected to something?
  5. #5
    Join Date
    Apr 2012
    Posts
    1,981
    Points
    11,015
    Level
    25
    Quote Originally Posted by Faddei View Post
    No. In your original circuit pin 2, pin 6 and the capacitor were driven by pin 7 and a pull-up resistor. Now they are driven by the output (pin 3) instead.
    It should work. If you vary the resistor between say 10K and 100K, it should give a frequency range of about 10 to 1.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Dec 2007
    Posts
    23
    Points
    1,858
    Level
    10
    Thanks guys. This porblem is solved.
    •   Alt10th August 2012, 07:30
      advertising
  7. #7
    Points: 36, Level: 1
    Join Date
    Mar 2013
    Posts
    7
    Points
    36
    Level
    I want to generate frquency from 17 Hz to 17KHz. how to calculate frquency by above circuit?
    can anyone sugges me the values of R and C?
    Please reply
  8. #8
    Full Member level 1
    Points: 703, Level: 5
    Join Date
    Feb 2013
    Bengaluru,Karnataka,INDIA
    Posts
    109
    Points
    703
    Level
    You can try this link....http://www.engineersgarage.com/contr...standing-ic555
    But this uses two resistor,Do you also need one transistor?
  9. #9
    Join Date
    Mar 2013
    Posts
    7
    Points
    36
    Level
    I want to do it by one resistor. and transistor for what purpose? I am using this frequency in one unit called tachometer calibrator
  10. #10
    Full Member level 1
    Join Date
    Feb 2013
    Posts
    109
    Points
    703
    Level
    Okay... sorry it is resistor not transistor
  11. #11
    Join Date
    Mar 2013
    Posts
    7
    Points
    36
    Level
    Now please help me to do that.. I have used 100k pot and 1uf capacitor. Now for 84.70k I got 17Hz but for 17KHZ it should be 84.70ohm but by 100k pot its not possible to achieve 84.70ohm. I am trying another calculation. If you got any idea then please tell. And one another thing by these values only on time is of required frequency but i want total on time +off time equal to 17 Hz to 17KHz
  12. #12
    Join Date
    Apr 2012
    Posts
    1,981
    Points
    11,015
    Level
    25
    A good way is to use 3 capacitors, say 1uF, 100nF and 10 nF, with a switch to select which capacitor is in circuit. Then put a resistor of say 6K8 in series with the potentiometer to limit the frequency range for each switch position.
    That should give frequency ranges of about 15Hz to 200Hz for the first switch position, 150Hz to 2000Hz for the second switch position, and 1500Hz to 20000Hz for the third switch position
    •   Alt6th March 2013, 15:31
      advertising
  13. #13
    Join Date
    Mar 2013
    Posts
    7
    Points
    36
    Level
    Thanks.. I have got the solution..
  14. #14
    Full Member level 1
    Join Date
    Feb 2013
    Posts
    109
    Points
    703
    Level
    Thank you godfreyl.....I made it!!! 3 capacitor solution is good one
