+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Advanced Member level 2
    Points: 3,787, Level: 14
    Join Date
    Apr 2010
    Chennai,India
    Posts
    609
    Points
    3,787
    Level
    14
    IPC standard for Through hole components and Naming ??
    HI every one,
    right now i am arranging Through hole footprints so i like to arrange in IPC standard,which IPC standard need to follow for Through hole components and Naming for Through hole also ..(IN IPC-7351 Land Pattern Naming Convention is available like that i need Naming convention for Through hole components )please any one reply for this thread...
    kapil
    •   Alt6th August 2012, 07:08
      advertising
  2. #2
    Points: 5,187, Level: 17
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    Re: IPC standard for Through hole components and Naming ??
    Please see attached PDF it has SMT and Thru Hole naming convevtion.
    •   Alt6th August 2012, 08:01
      advertising
  3. #3
    Join Date
    Apr 2010
    Chennai,India
    Posts
    609
    Points
    3,787
    Level
    14
    hi ricky,
    is it possible to get standard footprint (IPC standard ) for PADS 2005.any organization providing footprints ??
    kapil
    •   Alt7th August 2012, 06:11
      advertising
  4. #4
    Join Date
    Apr 2010
    Chennai,India
    Posts
    609
    Points
    3,787
    Level
    14
    hi ricky,
    if i follow the IPC standard , how can i differentiate male and female connector (like D-sub ) i could not find any name conversion has not given in this pdf
    kapil
  5. #5
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    The IPC naming convention for Connectors is "Manufacture_Part Number".
    Part number is always unique for each part so you will be able to differentiate from that only.
    If you still want to have some different naming convenetion you can add some suffix in the end to differentiate between male and female connectors (e.g. "_Y" for male and "_X" for female)
    •   Alt17th September 2012, 04:36
      advertising
  6. #6
    Advanced Member level 5
    Points: 12,048, Level: 26
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,914
    Points
    12,048
    Level
    26
    PADsis owned by Mentor, who recently bought Valor, who purchased PCBLibraries...
    So Menter own all the IPC-7351 wizzards etc, I believe they will provide PADS footprints, check with your PADS VAR
