Kowalsky
Newbie level 2
Hi!
I have problem with OPNET 14.5 installation on Win 7. I installed VS 2005 first, and than automaticaly update VS on SP2 and installed three OPNET modules. After that I imporeted 13 variables as they put in the installation guide.
Variable*1:**Path
Value:*
;C:\Visual8\Common7\IDE;C:\Visual8\VC\BIN;C:\Visual8\Common7\Tools;C:\Visual8\Com
mon7\Tools\bin;C:\Visual8\VC\PlatformSDK\bin;C:\Visual8\SDK\v2.0\bin;C:\Windows\Micr
osoft.NET\Framework\v2.0.50727;C:\Visual8\VC\VCPackages;C:\Visual8\SDK\v2.0\Bin;C:\
Windows\Microsoft.NET\Framework\v2.0.50727;C:\Visual8\VC\bin;C:\Visual8\Common7\I
DE;C:\Visual8\VC\vcpackages;*
Variable*2*:**INCLUDE*
Value:*
C:\Visual8\VC\ATLMFC\INCLUDE;C:\Visual8\VC\INCLUDE;C:\Visual8\VC\PlatformSDK\inclu
de;C:\Visual8\SDK\v2.0\include;*
Variable*3:**LIB*
Value:*
C:\Visual8\VC\ATLMFC\LIB;C:\Visual8\VC\LIB;C:\Visual8\VC\PlatformSDK\lib;C:\Visual8\SD
K\v2.0\lib;*
Variable*4:**LIBPATH*
Value:*
C:\Windows\Microsoft.NET\Framework\v2.0.50727;C:\Visual8\VC\ATLMFC\LIB;*
Variable*5:**NetSamplePath*
Value:**C:\Visual8\SDK\v2.0;*
Variable*6:**DevEnvDir*
Value:**C:\Visual8\Common7\IDE;*
Variable*7:**FrameworkDir*
Value:**C:\Windows\Microsoft.NET\Framework;*
Variable*8:**FrameworkSDKDir*
Variable*9:**FrameworkVersion*
Value:**v2.0.50727;*
variable*10:**VCBUILD_DEFAULT_CFG*
value:**Debug^|Win32;*
Variable*11:**VCBUILD_DEFAULT_OPTIONS*
Value:**/useenv;*
Variable*12:**VCINSTALLDIR*
Value:**C:\Visual8\VC;*
Variable*13:**VSINSTALLDIR*
Value:**C:\Visual8;*
At the end I run Use*License*Maker**(crack*file).
When I tried to start program (as administrator) I got message that Required Application configuration file 'opgalaxy7.vr' is missing. Normaly this file is located in ...
What is the a solution of the error?
Variable*1:**Path
Value:*
Value:*
Variable*3:**LIB*
Value:*
K\v2.0\lib;*
Value:*
Value:**/useenv;*
