+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 5
    Points: 783, Level: 6
    Join Date
    Apr 2012
    Bulgaria :(
    Posts
    86
    Points
    783
    Level
    forward vs flyback topology
    what is better for low noise,ripple and high efficiency
    forward or flyback
    •   Alt31st July 2012, 11:16
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,543, Level: 32
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,438
    Points
    17,543
    Level
    32
    Re: forward vs flyback topology
    It depends upon the current and voltage requirements but, in general, a forward type converter would have lower noise, ripple, and (perhaps) better efficiency. The forward converter is also usually a more complicated design.
    Zapper
    Curmudgeon Elektroniker
    1 members found this post helpful.
    •   Alt31st July 2012, 17:07
      advertising
  3. #3
    Points: 27,973, Level: 40
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    5,877
    Points
    27,973
    Level
    40
    whatever the input current waveform shape of a forward converter, you can make a flyback with that same shaped input wavefrom.
    so from the input its exactly the same.
    They are indeed the same.......maybe at the secondary the forward can have a bit lower peak current peak.
    But two transistor forward and two transistor flyback are both applicable where the other one is.
    •   Alt31st July 2012, 19:59
      advertising
  4. #4
    Member level 5
    Join Date
    Apr 2012
    Bulgaria :(
    Posts
    86
    Points
    783
    Level
    but how to control 2 switch forward with pwm designet for single switch
    if i use a transformer or some logic, or single switch forward?
    also for high power, low noise 100v 25a what topology should i use
    and if i filter it with 2 differential filters, i should get very low noise (<800uV i hope)
