+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Points: 1,923, Level: 10
    Join Date
    Mar 2003
    Posts
    7
    Points
    1,923
    Level
    10
    importing dxf to orcad capture
    I have many drawing files with DXF type, and they are translated by Orcad, Now I want to import those DXf files to Powerpcb to layout, but I can't do it although I try with many ways.
    Could someone tell me how to do?
    Tks.
  2. #2
    Join Date
    Mar 2003
    Posts
    7
    Points
    1,923
    Level
    10
    pads netlist import
    No one?
    Waiting!!!!!
    •   Alt27th October 2004, 03:33
      advertising
  3. #3
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    how to translate orcad to dxdesigner
    Try to download ViewMate. It's evaluation verion is free.
    However I am not sure if this software will be able to translate DXF file into your format.
    You can also try NumberOne EasyPc; same story as above... 8)
    •   Alt27th October 2004, 04:07
      advertising
  4. #4
    Join Date
    Mar 2003
    Posts
    7
    Points
    1,923
    Level
    10
    dxf and schematic
    NumberOne EasyPc? Is it also one CAM software?
    As I know, Viewmate is one CAM software, maybe not unable to translate, but I will try anyway.
    Tks,
    •   Alt27th October 2004, 04:41
      advertising
  5. #5
    Advanced Member level 2
    Points: 5,440, Level: 17
    binu G's Avatar
    Join Date
    Jan 2003
    Bangalore
    Posts
    501
    Points
    5,440
    Level
    17
    How to translate DXF files to netlist that Pads can import
    jstiger
    1.rst you have to convert the dxf files to gerber using cam350.
    2.generate the nc file manually if not avalible.
    3. map the layer stackup
    4convert draw in flash.
    5 create the parts and name the pads you can see in teh tools. (cam350)
    6.extract the netlist.
    7.Export to cad formate.
    you have a few format avalible while export.
    select the sutiable one.
    binu g
  6. #6
    Join Date
    Mar 2003
    Posts
    7
    Points
    1,923
    Level
    10
    Sorry for misunderstanding!!!!
    I should be add one sentence before: Those DXF files are schematic files, not layout drawings.
    Sorry!
  7. #7
    Points: 15,672, Level: 30
    Join Date
    Feb 2002
    USA
    Posts
    1,371
    Points
    15,672
    Level
    30
    Re: How to translate DXF files to netlist that Pads can impo
    No - you can't convert a DXF drawing to a schematic that can be used by an EDA program. A DXF drawing is just a bunch of lines - it doesn't have any intelligence about components or pins.
    Any schematic you get from a DXF drawing is going to be just a picture of the schematic. It won't be anything you can use for automated netlist generation, or automated PCB generation.
  8. #8
    Join Date
    Mar 2003
    Posts
    7
    Points
    1,923
    Level
    10
    ou!!!I see.
    Thanks,Hose_cat.
    I will draw those schematic and layout myself.
    •   Alt28th October 2004, 01:56
      advertising
  9. #9
    Member level 4
    Points: 2,026, Level: 10
    Join Date
    May 2004
    Posts
    69
    Points
    2,026
    Level
    10
    you say these files were created thru Orcad?
    If so why not just use the Orcad tools to export a netlist from the schematic?
    If what you are saying was that you imported a dxf into Orcad then you'll have to redraw the schematic in Orcad using Orcads primitives and then you can export a netlist that powerpcb can use.
  10. #10
    Member level 1
    Points: 2,139, Level: 10
    Join Date
    Aug 2001
    Posts
    40
    Points
    2,139
    Level
    10
    I don’t understand exactly what you have and what you want to do. You said that you want to import those dxf files into PowerPCB and later you added that those are schematic files. PowerPCB is a layout tool and not a schematic capture tool.
    If you have a schematic done in OrCAD Capture you can use E-Studio from E-Tools Company to translate it to DxDesigner (assuming that you use DxDesigner as schematic capture tool). If you have only the dxf file generated from OrCAD, you can use CAM350 to convert it into HPGL format and to import it into DxDesigner. Of course the result will be a graphic schematic and not an intelligent schematic, but it may help you to redraw your schematic.
