+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 2
    Points: 2,769, Level: 12
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    India
    Posts
    131
    Points
    2,769
    Level
    12
    How to define DC Gain of Operational Amplifier or OTA ?
    I have very basic question in mind. How do we decide DC Gain of OPAMP or OTA irrespective of application ? Does it decide on basis of settling error voltage or it has some other relation.
    If you have any good and basic refernce for it. then, please share it.
    •   Alt22nd July 2012, 13:58
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,702, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    Re: How to define DC Gain of Operational Amplifier or OTA ?
    What do you mean?
    Are you going to design an amplifier?
    Or do you ask for measurement techniques?
    •   Alt22nd July 2012, 14:39
      advertising
  3. #3
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    DC gain is determined by feedback ratio Rf/Rin for inverting and for non-inverting input DC gain = { 1+ Rf/Rin }ratio
    Details
    http://en.wikipedia.org/wiki/Operational_amplifier
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    •   Alt22nd July 2012, 14:45
      advertising
  4. #4
    Full Member level 2
    Achievements:
    7 years registered
    Join Date
    Aug 2007
    India
    Posts
    131
    Points
    2,769
    Level
    12
    Hi LvW,
    My question is What are factor we consider while deciding Gain as specifications ? Does Settling Error has relation with it ? then how ?
    Hi LvW,
    Hi LvW,
  5. #5
    Points: 17,767, Level: 32
    Achievements:
    7 years registered
    crutschow's Avatar
    Join Date
    Feb 2012
    L.A. USA Zulu -8
    Posts
    3,479
    Points
    17,767
    Level
    32
    The desired gain is determined by the application. For example if you have a 0-100mV peak signal from a sensor that you want to expand to the 0-5V range of an A/D converter than you need a gain of 5/0.1 = 50.
    The settling time can be affected by the gain. You have to look at the gain-bandwidth and settling time specs for the particular op amp you are using to determine what that is.
    Edit: Deleted double post.
    Zapper
    Curmudgeon Elektroniker
    •   Alt22nd July 2012, 15:50
      advertising
  6. #6
    Advanced Member level 3
    Points: 7,253, Level: 20
    checkmate's Avatar
    Join Date
    Feb 2004
    Toilet Seat
    Posts
    833
    Points
    7,253
    Level
    20
    You have already answered your own question.
    The main consideration is the error that you will see at the output when non-ideal circuits are used.
    This error has various components
    1. Input common-mode variation
    2. Input-referred offset
    3. Gain error, which is derived from feedback network accuracy and opamp open loop gain
