+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 5
    Points: 1,556, Level: 9
    Join Date
    Apr 2009
    Posts
    89
    Points
    1,556
    Level
    9
    Zener Diode vs. TVS Diode
    Are there any difference between TVS diode and Zener Diode or both devices are same?
    if TVS diode is something else, can you name some models?
    Thank you
  2. #2
    Super Moderator
    Points: 69,608, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,378
    Points
    69,608
    Level
    64
    Re: Zener Diode vs. TVS Diode
    They are very similar but nt the same. A Zener diode behaves like a normal diode in the forward (conducting) direction, it's rated 'zener' voltage is the reverse breakdown voltage. A TVS doesn't conduct in either direction until it's breakdown voltage is reached. You can think of a TVS are being two Zener diodes in series, pointing in opposite directions.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
    •   Alt20th July 2012, 09:08
      advertising
  3. #3
    Member level 5
    Join Date
    Apr 2009
    Posts
    89
    Points
    1,556
    Level
    9
    can you please name some models of this kinda diode?
  4. #4
    Full Member level 4
    Points: 1,132, Level: 7
    jasonc2's Avatar
    Join Date
    Jun 2012
    NYC, USA
    Posts
    204
    Points
    1,132
    Level
    7
    Blog Entries
    Quote Originally Posted by ata90 View Post
    http://www.mouser.com/Circuit-Protec...5g3g?&SAP=true
    •   Alt20th July 2012, 10:22
      advertising
  5. #5
    Member level 5
    Join Date
    Apr 2009
    Posts
    89
    Points
    1,556
    Level
    9
    Please notice the parts shown by red-rectangle bellow.
    Are these parts good enough to protect MOSFET from transient over voltage and over current?
  6. #6
    Member level 3
    Points: 439, Level: 4
    Join Date
    Nov 2011
    Posts
    55
    Points
    439
    Level
    zener will works under reverse bias condition and you will get the constant voltage across it when you bias it.
    TVS is nothing but,transient voltage suppressor,in SMPS for dissipate the leakage inductance energy in the transformer ie.,just like a snubber diode.
    •   Alt20th July 2012, 11:33
      advertising
  7. #7
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    Your despription applies only to bidrectional TVS diodes. But you get unidirectional TVS diodes as well, which are in fact nothing but power Z-diodes.
  8. #8
    Member level 5
    Join Date
    Apr 2009
    Posts
    89
    Points
    1,556
    Level
    9
    How about my work? is it configure correctly for over voltage and over current suppression?
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    There's no overcurrent protection (e.g. to handle motor short or stall) in your circuit and it won't be easy to achieve.
    The free wheeling diode is essential, the TVS diodes are not neccessarily required and may possibly affect the cicuit performance.
    Vds overvoltage is also limited by the FET avalanche breakdown capability (up to a certain energy level). Vgs overvoltage should be strictly avoided, but as long as the driver supply is properly bypassed, it won't occur. The 100 ohm series resistor will increase switching times and increase losses, a problem with higher PWM frequencies.
    By the way, tt's not clear how the high side driver can work in the shown circuit.
  10. #10
    Advanced Member level 5
    Points: 19,372, Level: 33
    Achievements:
    7 years registered
    Join Date
    Jan 2011
    Posts
    3,217
    Points
    19,372
    Level
    33
    It's not quite correct to say that normal zener and TVS diodes are the same. TVS diodes are engineered for withstanding extremely high peak-to-average power. And in my experience, I've found that TVS diodes work poorly for simple low-power clamping applications where you would normally use a zener diode. They tend to have much higher zener impedance at low signal levels.
