+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 2
    Points: 344, Level: 3
    Join Date
    May 2012
    Posts
    48
    Points
    344
    Level
    Altium Designer: Back annotation (update schematic with net changes from PCB)
    Hello everyone,
    I would like to seek advice on the proper way to doing back annotation with Altium Designer.
    What is the proper way to update a schematic from PCB with net name changes?
    •   Alt17th July 2012, 09:22
      advertising
  2. #2
    Full Member level 1
    Points: 764, Level: 6
    Join Date
    Jun 2012
    Posts
    100
    Points
    764
    Level
    Re: Altium Designer: Back annotation (update schematic with net changes from PCB)
    In pcb,tools...> Re Annotate, there itself select particular position press ok here one .WAS file will be generate, After that go to schematics tools...> back annotate schematics then select corresponding .WAS file. and press Accept changes. Just show in below images
    1 members found this post helpful.
    •   Alt17th July 2012, 09:49
      advertising
  3. #3
    Full Member level 3
    Points: 3,002, Level: 12
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    Join Date
    Mar 2012
    bangalore
    Posts
    187
    Points
    3,002
    Level
    12
    Blog Entries
    Tools/Re-annotate
    In PCB Editor
    Design/update schematics go to schematics compile it.
    Again In Schematic Editor
    Design/update PCB
    •   Alt17th July 2012, 09:52
      advertising
  4. #4
    Member level 2
    Join Date
    May 2012
    Posts
    48
    Points
    344
    Level
    I am getting 0kb .WAS file generated from the Re-annotate command execution.
    It won't allow me to back annotate the schematic. Is there a missing setup?
  5. #5
    Full Member level 1
    Join Date
    Jun 2012
    Posts
    100
    Points
    764
    Level
    Oh! But re annotate should be generate .was file with data, can i share ur pcb ?
