+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Full Member level 1
    Points: 2,569, Level: 11
    Join Date
    Apr 2003
    Posts
    112
    Points
    2,569
    Level
    11
    p-type guard ring, ic design
    hi guys
    can any one tell me what guard rings are and how they work..
    can someone also tell me how they are used to prevent Latchup in cmos circuits
    regards
    rogger123
    •   Alt22nd October 2004, 16:17
      advertising
  2. #2
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    Re: guard rings
    They were originally used in analog circuits made on PC boards. They surround an area where surface currents are a potential problem. By putting a potential on the ring that is equal to the potential of the circuit portion inside there is a zero potential difference across the PC material and so no leakage currents flow across the PC board surface.
    2 members found this post helpful.
  3. #3
    Full Member level 1
    Join Date
    Apr 2003
    Posts
    112
    Points
    2,569
    Level
    11
    Re: guard rings
    hi flatulent,
    does the same concept apply when they are used on the substrate and well for cmos layout ?
    what we basically do is have a p-type diffusion on a p-type substarte and then a p-type ring around this diffusion(is my undrstanding correct?).
    but how will this help in
    a) reducing the substarte resistance
    b) taking care of injected minority carriers
  4. #4
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    Re: guard rings
    I would expect the P diffusion is of much higher doping density than the substrate. I am not familiar with the details of this structure in MOS. Is some potential applied to these extra diffusions? The higher doping density would cause any stray n carriers to be combined more quickly than they would in the substrate and therefore be less likely to travel a long distance and cause problems at the end of their longer travels.
    I have not done any IC design in 30 years. Back then it was all bipolar and each BJT was in its own area surrounded by the opposite polarity diffusions and substrates.
    •   Alt23rd October 2004, 05:42
      advertising
  5. #5
    Full Member level 1
    Join Date
    Apr 2003
    Posts
    112
    Points
    2,569
    Level
    11
    Re: guard rings
    hi flatulent,
    yes a potential is applied. for a n+ it is connected to Vdd and for a p+ it is connected to Vss.
  6. #6
    Full Member level 1
    Join Date
    Apr 2003
    Posts
    112
    Points
    2,569
    Level
    11
    Re: guard rings
    hi flatulent,
    they also have another configuration. where a n+ diffusion is used within a p+ guard ring on a p+ substrate. the p+ guard ring is then tied to Vss. the opposite applies for n+ guard ring. now would it function in a similar manner as the previous configuration which just uses a p+ guard ring on a p+ substrate without any diffusion?
  7. #7
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    Re: guard rings
    It is difficult to guess without more construction details. The reverse biased pn junction may use the depletion region extending into the substrate to block stray carriers. It also may be used to reduce capacitive and conductive coupling between parts of the circuit.
  8. #8
    Full Member level 3
    Points: 2,982, Level: 12
    Join Date
    Feb 2004
    Bangalore, India
    Posts
    184
    Points
    2,982
    Level
    12
    Re: guard rings
    hi
    if u see a high performance circuits, a lot of devices will carry a huge current which disturbs other nearby devices. so we protect it by putting a guard ring, so that it will not affect other devices.
    •   Alt26th October 2004, 07:46
      advertising
  9. #9
    Member level 5
    Points: 2,045, Level: 10
    Join Date
    Sep 2004
    Posts
    86
    Points
    2,045
    Level
    10
    guard rings
    simply, guard ring can be used to keep signal integrity.
    VDD VSS line, or sandwitch of them can be applied for it
