+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 1
    Points: 88, Level: 1
    Join Date
    Jul 2012
    Posts
    Points
    88
    Level
    need help with 13001 transistor in Mobile charger.
    Today my mobile charger got faulty.
    I tried to check and repair. I found a transistor 13001 does not show any activity while checking with multimeter. I thought it is open (Break) and i purchase 2 new one from local shop.
    but when i check that new one with multimeter it also doing same.
    My checking method is as FOLLOWING:
    I set multimeter on (Alarm / connectivity / diode) testing.
    then connect red and black probe on emitter and collector. then reverse. and at last connect base.
    but nothing appears in meter display.
    Now my question is that is there any other method to check or i have bought 2 more faulty transistors.
    The circuit diagram is similar with attached pic.
    SORRY FOR BAD ENGLISH
    Click image for larger version.
Name:	mobile charger.JPG
    •   Alt8th July 2012, 21:10
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,088, Level: 33
    Achievements:
    Created Blog entry Created Album pictures 7 years registered
    goldsmith's Avatar
    Join Date
    Dec 2010
    Tehran - IRAN
    Posts
    3,982
    Points
    19,088
    Level
    33
    Blog Entries
    8
    Re: need help with 13001 transistor in Mobile charger.
    Dear Ayazhaider
    Hi
    Are you sure that that diode in snubber circuit is 1n4007 ? isn't it a UF4007 ?
    And are you sure that is a BJT ? isn't that a mosfet ? can you test it ?
    Best Wishes
    Goldsmith
    When you sensed that i can help you , feel free to ask me .
    Experience is a good professor of mine !
    The only thing that i couldn't understand yet , is why humans should fight together ? why not helping each other to have a better world ?
    •   Alt8th July 2012, 22:15
      advertising
  3. #3
    Full Member level 5
    Points: 2,448, Level: 11
    Join Date
    Jun 2012
    Bonn, Germany
    Posts
    290
    Points
    2,448
    Level
    11
    Hello Ayazhaider,
    This setting is ok.
    If now you don't have any reading on your display the transistor has no short circuit.
    Now, test between base and emitter. The reading must show a diode. Do the same measuring between collector and base. Also you must see a diode.
    Are both diodes are ok, you transistor is ok also.
    I think you don't buy faulty transistors.
    Often the 2 capacitors C4 and C5 lost their capacity. Also check the resistors R7 and R10. Sometimes the get high-resistance. Then the power supply will not start.
    I hope it will help you.
    Best regards
    Rainer
    PS: Sorry, if my English is not so good.
