Unable to connect resistor footprint to LED footprint
DatsAbk
Member level 3
Hello,,
I have designed a PCB using ARES Proteus 7.6.I have tried a lot but I'm unable to find a solution to connect the resistor footprint to LED footprint.I tried routing manually but the track doesnt terminate and give error on right clicking to terminate.
I also face the same problem in connecting voltage regulator output to Vdd of my PIC controller
Help sooooooooooonnnnnnnnnnnnnnn................:sad::-|:!:
i think the problem is power source selection.
  • video_tutorial.rar
    V
Yes you are right. But using a gnd triangle symbol upside down for power would explain one error. Consider using squares or other std power symbols with different shades or follow ANSI or ISO std.
