+ Post New Thread
Results 1 to 13 of 13
26th June 2012, 12:48 #1
How to wire / connect a off delay timer with a contactor ?
talking & asking about the electromechanical off delay timer
thanksLast edited by danishdeshmuk; 26th June 2012 at 13:01.
26th June 2012, 12:59 #2
- Join Date
- Mar 2007
- Location
- 12°58' N77°38'E
- Posts
- 752
- Helped
- 71 / 71
- Points
- 6,081
- Level
- 18
Re: How to wire / connect a off delay timer with a contactor ?
can you please elaborate your requirement ?
Thanks
26th June 2012, 13:07 #3
Can i turn on or turn off a 3 phase blower with an electromechanical off delay timer ?
26th June 2012, 14:56 #4
- Join Date
- Jun 2012
- Posts
- 19
- Helped
- 2 / 2
- Points
- 439
- Level
- 4
It depends what your blower's on/off sequence is. If its a simple power switch, I assume you could just use a relay to toggle the power on and off with your timer.
Need more details...
26th June 2012, 17:21 #5
its a 3 phase blower with a 3 phase contactor
26th June 2012, 17:32 #6
- Join Date
- Jun 2012
- Posts
- 19
- Helped
- 2 / 2
- Points
- 439
- Level
- 4
well to be safe, you can put a relay on each phase... this would be the same as unplugging it when you turn all three relays off.
27th June 2012, 18:16 #7
would you send/provide me the schematic to how to do that ?
27th June 2012, 18:31 #8
- Join Date
- Sep 2010
- Location
- Pancevo-Belgrade, Serbia
- Posts
- 6,427
- Helped
- 1731 / 1731
- Points
- 33,525
- Level
- 44
Yes you can switch contactor induction coil with simple switch or some control circuits. When you switch off coil of contactor all three and null on contactor is turned off, this depends from contactor which you are using, some contactors have different ports state from others. This induction coil is monophase and switch is simple.
28th June 2012, 17:14 #9
would you provide me the schematic or circuit of it ?
so that i could grasp it ........
28th June 2012, 17:48 #10
- Join Date
- Sep 2010
- Location
- Posts
- 6,427
- Helped
- 1731 / 1731
- Points
- 33,525
- Level
- 44
In my post #8 you see three contactors, third on right of picture can be used for three phase system switching. Controling of contactor switch off/on is done over A1 and A2 ports on it. On A1 is connected phase (one) and on A2 is connected null. In other words A1 and A2 represent coil of contactor like at relays, but this coil working on 220V. Also there is contactors with coils on 12V, 24V, 48V,...
You can use any control circuit what you whish. Here is my example of switching timer device :
I use mono phase mains outlet, if I need I can just replace that outlet with three phase and I can control three phase device. Timer is used to switch on some deivces each day at preset time, you can use any control circuit what you need.
Did you make Off Delay timer already ?
29th June 2012, 15:56 #11
where is electromechanical off delay timers in these two pictures ?
I just wished to see the schematic ....... where the wires should be connected at the off delay timer .......... NO contacts would be used or NC contacts would be used ......... in order that the contactor just switched on or off whatever else want to achieve in the example ?
1st July 2012, 12:42 #12
- Join Date
- Sep 2010
- Location
- Posts
- 6,427
- Helped
- 1731 / 1731
- Points
- 33,525
- Level
- 44
Circuit what I use is here, download my posted file all is in there "PCB V1.1.RAR" :
http://www.kmitl.ac.th/~kswichit/clock/clock.htm
Also there is other circuits, this is just one.
3rd July 2012, 20:44 #13
it doesn't have what i want ?
+ Post New Thread
Please login
