+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 6
    Points: 2,871, Level: 12
    Ogu Reginald's Avatar
    Join Date
    Oct 2011
    Nigeria
    Posts
    369
    Points
    2,871
    Level
    12
    What does it mean if a triac is said to be snubberless in its datasheet?
  2. #2
    Administrator
    Points: 69,157, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,157
    Level
    64
    Blog Entries
    re: What does it mean if a triac is said to be snubberless in its datasheet?
    A Snubber Circuit is designed to counter/reduce EMI and switching transients, i.e., voltage and current spikes, produced by the rapid switch associated with a Triac or similar components:
    DESIGN OF SNUBBERS FOR POWER CIRCUITS
    Snubber Circuit Design - Practical Tips
    Many switching components, like the Triac, used in power circuit designs now incorporate a Snubber Circuit. A component specified by its datasheet as Snubberless, simply indicates that the component does not incorporate a Snubber circuit. And depending on the circuit design an additional appropriate Snubber Cricuit will need to be included.
    BigDog
    The Edge... there is no honest way to explain it, because the only people who really know where it is are the ones who have gone over.
    -- Hunter S. Thompson
    •   Alt19th June 2012, 00:46
      advertising
  3. #3
    Advanced Member level 5
    Points: 34,469, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    Snubbers can be clamp diodes or small RC spike suppressors like 10Ω + 100pF @ 100MHz.
    If your driving impedance is lower, then you may need 1Ω 1000pF @ 100MHz.
    The key is your driving/load impedance and the maximum dv/dvt your triac can handle before it is false triggered by coupling thru the Miller capacitance to the gate...
    and the rated current translated into load impedance which may alter the RC equivalent circuit. Plastic caps are always used due to the self healing and very low ESR qualities rated at high voltage but in some cases for lower voltage parts, high insulated "zener" like diodes in reverse conduction mode can give the equivalent capacitance to snub reverse voltage spikes, and also protect the device if it is not a 4 quadrant triac. Otherwise an additional process for adding ceramic caps inside is used.
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
  4. #4
    Banned
    Points: 7,016, Level: 19
    Join Date
    Apr 2009
    New Jersey, USA
    Posts
    671
    Points
    7,016
    Level
    19
    Quote Originally Posted by bigdogguru View Post
    BigDog
    Actually, Snubberless Triacs typically don't require a snubber circuit because of their enhanced commutation performance. See this application note on the ST web site for details: http://www.st.com/mcu/modules/Splatt...dtemp/6785.pdf
    •   Alt1st January 2013, 20:40
      advertising
  5. #5
    Full Member level 6
    Join Date
    Oct 2011
    Nigeria
    Posts
    369
    Points
    2,871
    Level
    12
    From your post, does it means that snubberless triacs are good enough to be used without additional/ external snubber?
  6. #6
    Banned
    Join Date
    Apr 2009
    New Jersey, USA
    Posts
    671
    Points
    7,016
    Level
    19
    In many cases, Yes. But there are exceptions as detailed in the document I cited.
  7. #7
    Administrator
    Achievements:
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,157
    Level
    64
    Blog Entries
    Thomson Semiconductors were the first to market a three-quadrant TRIAC as the Alternators, later after the consolidation of Thomson Semiconductors into STMicroelectronics, the Alternators were marketed under the trademark Snubberless.
    The term Snubberless when used in conjunction with TRAIC was trademarked by STMicroelectronics and therefore limited its use in reference to Alternators/TRIACs to STMicroelectronics manufactured Alternistors (three-quadrant TRIACs).
    Although perhaps poorly worded, I was referring to the circuit incorporating the TRIAC as well as the example circuits typically provided in the devices datasheet.
    Quote Originally Posted by GSM Man View Post
    While there are now other manufacturers of three-quadrant TRIAC and although they cannot be marketed as Snubberless TRIACs, their common design enhancements do offer many of the features which reduce the need of a Snubber Circuit in some applications.
    However, stating categorically they don't require a Snubber Circuit would be incorrect as pointed in the appnote provide in the above reply:
    Reference: NEW TRIACS: IS THE SNUBBER CIRCUIT NECESSARY?, Section: IS IT ALWAYS POSSIBLE TO REMOVE THE SNUBBER CIRCUIT?, Page 4
    SNUBBER CIRCUIT ?
    The answer is not in the affirmative because
    sometimes it has other functions :
    improvement of the triac immunity against transients
    in the off state ;
    compensation of latching current at turn on (not
    dealt in this paper).
    Switching on and voltage perturbations can
    provoke overvoltages and fast voltage variations
    across the triac :
    this one could break over when the overvoltages
    are higher than its repetitive peak off state voltage,
    VDRM;
    due to the junction capacitance fast voltage variations
    create a gate current and could trigger the
    triac; the device limit is the rate of rise of the offstate
    voltage, dV/dt.
    The snubber circuit can improve the triac behavior
    in off-state. But its efficiency is linked to the values
    of series inductance L at the oscillation frequency
    of perturbations (typically higher than 100 kHz).
    We could add a saturable inductor in series with
    the triac when L is too low: particularly this is the
    case of resistive load.
    A three-quadrant TRIAC simply reduces the requirement for the implementation of a Snubber Circuit, however they do not alleviate the requirement of a Snubber Circuit in all applications.
    BigDog
  8. #8
    Achievements:
    Join Date
    Sep 2007
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
    With the advent of Sensitive Gate Triacs, you need a Snubber to prevent false triggering from dv/dt injection.
    This means you can cheaply drive motors with logic level currents using snubberless-sensitive gate with phase angle control of AC.
    Snubber-less designs have higher immunity to false triggering but still egress like crazy with reactive loads so snubbers may be needed for EMI egress and also possible high levels of ingress. but normal levels ,, not as advertised as moderate noise rejection is included by reducing bandwidth of noise ingress.
    "The T series is the latest addition to Snubberless™ Triacs and provides enhanced commutation for a given current rating. Immunity is also improved up to 5 times for a given current rating."
  9. #9
    Full Member level 4
    Points: 1,404, Level: 8
    Join Date
    Oct 2011
    Posts
    212
    Points
    1,404
    Level
    8
    How such snubberless TRIAC can be found for other manufacturers (not ST)?
    •   Alt20th February 2013, 17:00
      advertising
  10. #10
    Achievements:
    Join Date
    Sep 2007
    Posts
    6,667
    Points
    34,469
    Level
    45
    Blog Entries
    7
