+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 5
    Points: 2,378, Level: 11
    Sajjadkhan's Avatar
    Join Date
    Sep 2010
    Rawalpindi,Pakistan
    Posts
    307
    Points
    2,378
    Level
    11
    which printer is best for toner transfer?
    I have an old printer laserjet 1200 series by hp and i use it for toner transfer only. its 600dpi. problem is if i lay a pcb track of width more that 50th then it starts missing few tiny like dots and same happens when i have to cover unused area with copper. after preparing the pcb if i look it against the light then i see tinny areas and some bigger areas where light can pass through easily and it dosent look good. do i need higher dpi or a denser toner printer? what printer do you guys recommend?
    •   Alt18th June 2012, 22:18
      advertising
  2. #2
    Full Member level 5
    Points: 2,221, Level: 10
    sribangaram's Avatar
    Join Date
    Apr 2012
    INDIA.:/;:'" VIJAYAWADA
    Posts
    285
    Points
    2,221
    Level
    10
    Re: which printer is best for toner transfer?
    Dear Friend I think samsung 1200dpi Laser printer is toooooooo good for pcb make why because I am using that & transfar paper is VMS Professional colour Inkjet paper(5760dpi) I am getting the pcb very clear :smile:
    •   Alt18th June 2012, 22:58
      advertising
  3. #3
    Full Member level 6
    Points: 2,768, Level: 12
    Ogu Reginald's Avatar
    Join Date
    Oct 2011
    Nigeria
    Posts
    369
    Points
    2,768
    Level
    12
    I think the best laser jet for efficient and reliable transfer is the hp1018. It is serving me well even when i increase the power tracks to about 120 it is still clear.
    •   Alt19th June 2012, 09:30
      advertising
  4. #4
    Full Member level 5
    Sajjadkhan's Avatar
    Join Date
    Sep 2010
    Rawalpindi,Pakistan
    Posts
    307
    Points
    2,378
    Level
    11
    I have heard (may be its a rumor) that new laser jet printers are using new technology in which toner cant be stick to the pcb, any info?
  5. #5
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    Quote Originally Posted by Sajjadkhan View Post
    Its true. It is to save toner for economical reasons. So old printers are good for pcb making. Other important is toner ink and also the transfer medium. HP model 5L, 6L with original HP toner gives very good results. I've tried HP 1100, 1200 and some other latest model but the result is poorer even not usable.
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
    •   Alt20th June 2012, 09:19
      advertising
  6. #6
    Full Member level 5
    Sajjadkhan's Avatar
    Join Date
    Sep 2010
    Rawalpindi,Pakistan
    Posts
    307
    Points
    2,378
    Level
    11
    Quote Originally Posted by ALERTLINKS View Post
    I have good transfer medium. What is your experience in using orignal toner and refilled one?
    have you ever tried UV method? it seems on internet that it is good for making 2 sided pcbs but its very very hard with printer so no one bothers.
    Quote Originally Posted by sribangaram View Post
    i would like you to share your pcb picture with us, thanks.
