problem regarding simulation of vhdl code
shikha khandelwal
Newbie level 3
hi can you please guide me in the following vhdl code . my task is to get the time required for changing the change signal from 0 to 1 and hit signal 0 to 1 . i write my code ..during synthesization i got warning index value(s) doesn't match but still it is synthesized. but the problem is that in test bench waveform change signal is becoming 1 from the starting . According to me i want to find out delay for changing change signal with respect to reconf signal but it is becoming 1 with reconf signal i want some solution for this problem .. please help me .
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use ieee.numeric_std.all ;
use ieee.std_logic_unsigned.all;
use ieee.numeric_bit.all ;
entity mi is
port ( p0 :  in std_logic_vector(2 downto 0 ) ;
p1 :  in  std_logic_vector ( 2 downto 0 )  ; clk : in std_logic ; address : in unsigned(5 downto 0 ) ;
reconf : in std_logic ; change : out std_logic ; hit : out std_logic) ;
end mi;
architecture Behavioral of mi is
type entry is record
addres : unsigned( 5 downto 0 ) ;
proc : std_logic ;
end record ;
type   cacheblkpointer  is array ( 7 downto 0 ) of entry ;
signal cb : cacheblkpointer ;
type set is array( 0 to 3 , 0 to 1) of unsigned( 5 downto 0 )  ;
signal s : set  ;
begin
process(p0 , p1 , address , clk )
variable di  : integer  ;
variable discard : unsigned( 5 downto 0 ) ;
variable d : integer  := 1;
variable r : natural ;
variable pr : std_logic ;
variable x : positive ;
variable re  : integer ;
variable m : unsigned(5 downto 0 ) ;
begin
cb(0).addres <= "010000" ;
cb(1).addres <= "010100" ;
cb(2).addres <= "010011" ;
cb(3).addres <= "010011" ;
cb(4).addres <= "011110" ;
cb(5).addres <= "011110" ;
cb(6).addres <= "010001" ;
cb(7).addres <= "010111" ;
cb(0).proc <= '0' ;
cb(1).proc <= '1' ;
cb(2).proc <= '0' ;
cb(3).proc <= '0' ;
cb(4).proc <= '1' ;
cb(5).proc <= '0' ;
cb(6).proc <= '1' ;
cb(7).proc <= '0' ;
s(0,0) <= "000000" ;
s(0,1) <= "000000" ;
s(1,0) <= "000000" ;
s(1,1) <= "000000" ;
s(2,0) <= "000000" ;
s(2,1) <= "000000" ;
s(3,0) <= "000000" ;
s(3,1) <= "000000" ;
 change <= '0'  ;
 hit <= '0' ;
 if(reconf = '1' ) then
 for n in 0 to 7 loop
 pr := cb(n).proc ;
 x := conv_integer (unsigned(cb(n).addres)) ; -- x  = dividend
 if( pr = '0' ) then
 di := conv_integer (p0) ;
 d := conv_integer (p0) ; -- d = divider
 else
 d := conv_integer (p1) ;
 end if ;
 if( d = 1 ) then
 re  := 0 ; --re stands for remainder .
 end if  ;
 if( d > 1) then
 while ( d <= x) loop
 d := 2 * d ;
 end loop ;
 d := d / 2 ;
  x := x - d ;
  if( di < x) then
  d := di ;
  while( d <= x ) loop
   d :=  2 * d ;
    end loop ;
    d := d /2 ;
    x := x - d ;
  end if ;
  if ( di = x) then
  r :=  0 ;
  elsif (di > x) then
   r :=  conv_integer (p0) ;
    end if  ;
    if(pr = '0') then
     re := r  ;
     else
     re := r + conv_integer (p0) ;
     end if ;
     end if ;
     m := "000000" ;
     if( s(re,0) = m ) then
s(re,0) <= cb(n).addres ;
end if ;
if (s(re,0) /= m) then
if(s(re,1) = m) then
 s(re,1) <= cb(n).addres ;
 else
 discard := cb(n).addres ;
end if ;
end if ;
end loop ;
change <= '1' ;
for i in 0 to 3 loop
for j in 0 to 1 loop
 if ( s(i,j) = address) then
hit <= '1' ;
exit ;
else
hit <= '0' ;
end if ;
end loop ;
end loop ;
end if ;
end process ;
end Behavioral;
first of all - wheres the clock?
Secondly - It looks like you're a software guy. I suggest you delete all this code and draw the circuit you want on a peice of paper before writing any VHDL. VHDL is the description language, so if you dont know what circuit you want, how do you expect your code to work?
As said above, you have tried to write a computer program that can run step by step on a processor. vhdl is not a programming language. It is a descriptor language. You need to to think about a circuit and then describe it in vhdl. It might look ok as is on the simulator but it won't in a real electronic circuit.
As you people are saying that this is like of software programming I have been working on vhdl since last one month so may be some faults can be there .
I tried to do some changes in my program . I searched on the net and made it with the help of states.Now it is again synthesizing and implement design is also correct . but when i went for test bench wave form it is still not helpful . can you guide me that synthesis report of this program can be useful for me to find out the delay for becoming change signal from 0 to 1 . And there is one doubt also if it cant make any electronics circuit of code then why implement design becomes correct.
This time please give me any solution which i can take .. here is my code
library IEEE;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
entity om is
Port ( clk : in STD_LOGIC; p0 : in std_logic_vector( 2 downto 0 ) ; p1 : in std_logic_vector(2 downto 0 ) ;
reconf : in STD_LOGIC ;reset : in std_logic ; change : out std_logic ; hit : out std_logic ; address : in std_logic_vector(5 downto 0 ));
end om;
architecture Behavioral of om is
type cacheblkpointer is array ( 0 to 7 ) of std_logic_vector( 5 downto 0 ) ;
type cacheproc is array (0 to 7) of std_logic ;
signal p : cacheproc ;
type set is array( 0 to 3 , 0 to 1) of std_logic_vector( 5 downto 0 ) ;
signal s : set ;
signal discard : std_logic_vector( 5 downto 0 ) ;
type state_type is (s0,s1,s2,s3, s4,s5); --type of state machine.
signal next_s: state_type; --current and next state declaration.
signal pu : integer ;
begin
process( reset , reconf , next_s)
variable f : std_logic_vector( 5 downto 0 );
variable n : integer ;
variable g : std_logic ;
variable l : integer ;
variable h : integer ;
variable k : integer ;
variable c1 : integer ;
variable c2 : integer ;
variable r : std_logic_vector(4 downto 0 ) ;
variable rd : integer ;
variable red : integer ;
begin
if(rising_edge(clk)) then
next_s <= s0 ;
case next_s is
when s0 =>
if ( reset = '1') then
cb(0) <= "010000" ;
cb(1) <= "010001" ;
cb(2) <= "010011" ;
cb(3) <= "010101" ;
cb(4) <= "011001" ;
cb(5) <= "010101" ;
cb(6) <= "010101" ;
cb(7) <= "010101" ;
p <= "01000101" ;
hit <= '0' ;
change <= '0' ;
n := 0 ;
end if ;
next_s <= s1 ;
when s1 =>
if( n < 8 ) then
f:= cb(n);
g := p(n) ;
if( g = '0') then
pu <= conv_integer(unsigned(p0)) ;
else
pu <= conv_integer(unsigned(p1)) ;
end if ;
l := conv_integer(unsigned(f)) ;
for i in 1 to 63 loop
h := i-1 ;
k := i ;
c1 := pu * h ;
c2 := pu * k ;
if( c2 = l) then
r := "00000" ;
exit ;
end if ;
if( c2 > l) then
red := l - c1 ;
r := conv_std_logic_vector(red,5) ;
exit ;
end if ;
end loop ;
elsif ( n = 8) then
next_s <= s4 ;
end if ;
next_s <= s2;
when s2 =>
if (g = '0') then
rd := conv_integer(unsigned(r)) ;
else
rd := conv_integer(unsigned(r)) + pu ;
end if ;
next_s <= s3;
when s3 =>
if( rd > 0 and rd < 4) then
if(s(rd,0) = "000000") then
s(rd,0) <= "010000" ;
else
if(s(rd,1) = "000000") then
s(rd,1) <= "010000" ;
else
discard <= "010000" ;
end if ;
end if ;
else
end if ;
n := n + 1 ;
next_s <= s1;
when s4 =>
change <= '1' ;
next_s <= s5 ;
when s5 =>
if(s(i,j) = address) then
hit <= '1' ;
else
hit <= '0' ;
end if ;
end loop ;
end loop ;
end case ;
end if ;
end process ;
end Behavioral;
it looks like all you did was wrap a clock around your code.
Did you draw the circuit on a peice of paper before you re-wrote the code?
Also - VHDL point - you cannot use std_logic_arith and numeric_std in the same file because they conflict. You should delete std_logic_arith because it is non-standard.
Actually it is a code for cache reconfiguration according to partition size so i jst read paper i dont know what is its circuit i just imagine that this can work like this , so i think there is no hope now for this thing..
thanks
I see some problems:
- The purpose of the design, e.g meaning of input signals isn't said. How can we suggest a solution?
- The second attempt shows considerable changes, e.g. implementation of a state machine. But it seems to be hastily designed, not all states can be reached.
- There's a dubious reset construct. Reset, either synchronous or asynchronous, should work unconditionally, not only in one state.
- Some code details raise doubts, if you understand the nature of signal assignments in a process at all.
Now it is again synthesizing and implement design is also correct.
What do you mean with "correct" design? Hardware is behaving as intended? If so, you are talking about a simulation problem only?
The present VHDL code will in fact bring up some specific simulation problems due to uninitialized signals, e.g. next_s. Other than in real hardware, this signal will never get a defined state during simulation, all output signals will most likely stay undefined as well.
A HDL design finally synthesis to a logic circuit, in so far any synthesizable HDL code can be represented by a circuit. VHDL offers different levels of abstraction, you can code a problem without directly referring to hardware structures. But there's a certain risk to end up in a non-synthesizable construct if you don't well understand the requirements of the underlying logic hardware.
